- mordred1973
Initial stereo volume
I might have missed a similar question onhere, but is there wa way to set the volume of the radi, so that the next time you start the car is comes on a lower volume? My previous cars all had a function to set the switch on level (and in fact the last 2 had one that allowed the car to increase the volume itself as speed increased so you didn't need to do it manually)
Many thanks
- B50int
It should come back on at the volume it was last used at.
However, this was one on the issue identified by some users in earlier versions of the incontrol software. It was specifically mentioned as fixed by phase4 update (18c).
Jon
- mordred1973
oh yeah it comes back on at the volume it went off at, whereas most car have a preset lower volume for it to come back on at, so as it doesn't deafen you first thing in the morning. Assume that's something else that only cheaper cars have.
