  • harrythespider
    usb music
    Anyone successfully copied CD to USB and played through armrest port. I have 128GB stick and formatted and wrote all formats of recording to it MP3, WMA,etc (on separate occasions to test) but car says no media .
    Any advice?
    I may be wrong, but I have a vague recollection of this being discussed before and 128GB is too big?
    128 too big from memory as well
    I use a 128gb as below with no problems. Think it depends of how you format it and I can’t remember for the life of me what I did. Put it this way if FAT32 doesn’t work, pick something else and just try it, even if the manual says otherwise.
  • harrythespider
    Thanks Dangerdave. I chose 128Gb as previous posts have indicated that size for Nav updates. I have tried various drive formats inc FAT32 and various recording formats but to no avail. I might try a smaller stick just in case my car is 'sensitive'
    The one I’ve got is SanDisk. Particularly small. It gives me tons of room for music plus I have enough to download the map updates. Think the map updates are normally 25gb or thereabouts.
    Did you do the format to fat32 on a Mac or PC?
  • whited3
    From memory its got to be FAT32 from a PC. I run a 32GB stick with no dramas.
  • B McP
    I use a 128Gb Sandisk, PC formatted to FAT32. I store many DVD's in mp4 format. When I initially select the USB as the source I get the `no files found' message, but then I get a choice to search for audio or video files - I have not used it for Audio though as I use the on board Media Player to store CD's in WMA format and that works fine as I use the USB for Map updates and Video's. Selecting video shows all the mp4 files (I can even play three different videos from the USB at the same time if I choose to do so via RSE and front screen).
  • ForlornMTL
    Makes no difference either way.
    FAT32 is a format that is used that can be read and written by Mac, Windows, Linux and DOS.
    It's like asking if you filled your petrol tank with the right or left hand. If your D5 is petrol, whichever hand you used makes no difference. But if you put diesel in your petrol engine...that's a different format.
    On a Mac it's called MS-DOS(FAT).
    I've done it many times without any issues.
  • ForlornMTL
    Re: usb music
    Any advice?
    I have been using a 128GB without any issues for many months. It may even be a 256gb by now. I remember changing it a while back.
    I sometimes have issues with the infotainment suddenly deciding to not read the USB or Bluetooth iPhone as a choice for audio (they are greyed out but visible to the system). It will usually come back on it's own after a few minutes or the next time i start her up.
    Have you checked the ID3 tags of your MP3's ?
    I have mine set to ID3v2.4 (ID3v1 ID3v2.4).
    I use the Mp3tag software, available online for free. I make sure all the artist names, album names, song titles etc are the way i want it to be displayed.
    It also takes a bit of time when you first put a USB stick in the system.
    It needs to index your USB content so it can easily search it and display the content live when you browse. Every time you change the content of it, it needs to be re-indexed.
    I assume the system reads the size of the drive and if it's different from the last time it checked, it indexes it from scratch. Subsequent indexing might be shorter as it may recognize some of the content info and rewrite what is added and discard what is missing.
    Indexing has nothing to do with the size of your content but how many there are. A USB stick with 7 films will index 7 files. A USB stick with 4563 songs will have to index 4563 files. So it takes longer for a USB stick filled with audio rather than video.
  • harrythespider
    Thanks all for the info, I have a dilemma to use the stick for music it needs to be FAT32, but for map updates (25gb) probably exFAT, Although Dangerdave seems to use his 128GB for both, So totally confused now!!!
    Yep, I use mine for both. If it wasn’t minus 5C outside I’d say I would pull the memory stick in and check how it’s formatted. I do all my stuff like that on an Apple Air if that’s any help. Haven’t had a Windows machine in 20 years.
  • whited3
    When you do a map update the LR downloader will format the stick as required. Once installed you can go back to using it for what ever.
    Doesn’t do anything to mine when I download to it. In fact it’s the only stick I’ve used for music and updating the satnav.
