Sunshine arrived. Sunroof opened. Actually, it doesn’t feel fully open. How far should it open? In this photo it’s as far as it goes and I’m sure it use to be further.
There’s a reset sequence for the blinds and windows so assume same for sun roof. Should be in the manual ?
From iGUIDE app. Might help ?
Quote:
If the battery is disconnected, or the power supply is interrupted while the sunroof is partially open, it may need to be recalibrated.
Once the battery is reconnected, or the power supply is restored, recalibrate the sunroof as follows:
Switch on the engine.
With the sunroof and blinds closed, press the front of the roof switch and hold for 10 seconds. See ELECTRIC WINDOWS.
After 10 seconds, the sunroof and blinds fully close. If already in the closed position, an audible click sounds. Release the switch. Within 5 seconds, press and hold the front of the roof switch until the blinds and sunroof complete a full open and close cycle.
