    I know a tow bal can/eventually will break off if used for other stuff it’s designed for (use as a recovery point) but a fixed recovery point (without the screw, as you get with the removable tow bar), seems pretty solid to me?
  • LancsLad
    Did anyone confirm 100% that the electric deployable has a screw in only? If so i'm so glad I went for manual removable. Does make you wonder if in the event of being forced to recover someone via your electric deployable what sort of damage you may cause to the mechanism?
    Any recovery point could theoretically fail I guess but screw type are inherently prone to fail with heavy loading or snatching.
    Ive witnessed it....long story ..involving a Volvo and a telehandler... Rolling Eyes Rolling Eyes Embarassed
    But the Body mounted standard ones on D5 are better than most Ive seen on new production vehicles these days.
    I don’t see the recovery point on my D5 as the weakest point Wink
    IndusD4 wrote:
    I use rated shackles (4.5T or higher) to connect the snatch strap to a recovery point, at both ends.
    I have rated shackles, but I've just invested in some soft shackles rated at 11.3T. (https://gigglepin4x4.net/gigglepin-superop...1566-p.asp)
    I haven't had an opportunity to use them yet but they would hurt less if they hit you. Laughing
  • harrythespider
    I like them JonM, I just hope that the edges on the tow point doesn't chafe them.
    Need to find someone with an electrically deployable two bar and get them to remove the plastic tow cover and take a picture as I did for the removable one
  • JackNorris
    Ill be taking one as soon as can, if anyone can get one before that works Thumbs Up
    LancsLad - Looks like it is the case.
    There's a drawing in the installation instructions that shows the hole to screw the loop in to.
    JonM wrote:
    [I have rated shackles, but I've just invested in some soft shackles rated at 11.3T. (https://gigglepin4x4.net/gigglepin-superop...1566-p.asp)
    I'll look into those, like you say if they come loose they would do a lot less damage.
    After using any recovery gear you need to inspect it for damage. And replace it if needed!
    Correct, the fixed recovery point with the removable tow bar is the one to use.
  • JackNorris
    Had a cheeky look before pick up today.
  • LancsLad
    well that settles that then!
    Gone are the days of hang on I'll just grab the Disco and drag you out... Whistle
    That one point pretty much sums up Landrovers Future direction i guess... Rolling Eyes
  • RDR
    Mental note don't order the deployable tow bar then, I've pulled many a fence post and tree stump out the ground using the recovery point on the D4 don't know what i'd do without one.
    MY23 Range Rover PHEV
    Not completely, you still have a proper recovery eye at the front. So turn around and reverse drag someone out.
  • harrythespider
    Just a thought, Previous Discos had a seperate steel chassis with the tow eye attached so very substantial. Would it actually be a good idea to snatch tow using the D5 that doesn't have such a robust chassis ???
    I don't think I would be comfortable trying it.
