  • harrythespider
    Yes, I've learnt from experience, that sometimes guns blazin' results in total embarrassment Embarassed
    So I try now to at least get some background info so I can have a semi intelligent discussion with the other party and then decide if they're taking the proverbial,
    BUT in this instance, if the recommendation as detailed in the previous post is JLR's doctrine, it should be included in the 24 mth/second service and following schedules detail. My concern now is.. why aren't all dealers/ service providers singing from the same hymn sheet, especially if a fault develops due to lack of maintenance could be mega expensive to rectify.
    I suspect that if the true cost of servicing new cars was properly advertised, then some customers would walk away, although ultimately ALL new cars (irrespective of the purchase price) with air con will suffer the higher level costs due to the R1234yf refrigerant .
    Blackbeltbob wrote:
    Well you have gasted my flabber there.
    So they might actually have done the right thing and not been too harsh on price.
    Dam. Was getting ready for a rumble.
    Many thanks for the great detail though. Fully appreciated.
    Still, £250 for a top up is very steep considering the new system measures the amount needed and recovers as much of the gas as possible.
    Car going in for its first service next week , so will ask the mechanic if the AC top up is included in the 5 year service plan, and will report my findings on here Rolling Eyes
  • bammmy
  • Blackbeltbob
    The dealer did confirm that its not covered in the service plan - bit of a misnomer then I would suggest.
    They also said the brake fluid isn't either
    You're right that we should take all these things into consideration. I remember when I bought my first 4x4 - a Daihatsu Fourtrack - I got prices of sundries ie brake discs, exhaust etc to see what I was getting into. I just assume now with LR to get fleeced Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
    Stuff like brake pads, discs, clutch, tyres, etc, general wear and tear stuff is not covered by any manufacturer as far as i am aware with regards to a service plan.
    Will have to pay extra, unless its covered under warranty like the engine.
    No mention of A/C at my 2 year service, this is what they did (?)
    Check condition and security of seats and seat belts.
    Check operation of all lamps, horns and warning indicators.
    Check operation of Windshield and headlight wipers and washer jets.
    Select the LOW range gears and drive the vehicle 3 to 4 vehicle lengths then re-select HIGH range gears.
    Renew pollen filter.
    Check tyre pressures, condition, tread depth, signs of uneven wear and suitability (including spare).
    Inspect brake pads for wear, calipers for leaks and disks for condition.
    Renew fuel filter element.
    Check operation of door locks, hinges, door checks, bonnet catch and fuel flap (do not lubricate).
    Check anti-freeze specific gravity.
    Check/top up coolant level.
    Replace the air cleaner element.
    Check condition of ancillary drive belt.
    Check/top-up brake fluid levels and screen washer reservoirs.
    Renew engine oil and filter.
    Clean debris from auxiliary oil cooler(s) and radiator(s).
    Using the Jaguar Land Rover approved diagnostic tool, check the DEF level.
    Check for free play in all suspension and body mounting rubbers.
    Check ball joints anchors, steering system tie rods, and also the condition of the ball joints and protective boots.
    Check visually brake servo hose, brake, fuel and PAS pipes, unions and electrical harnesses for chafing, leaks and corrosion.
    Check for fluid leaks.
    Check exhaust system for leaks, security and damage.
    Check steering rod ball joint fixings and condition of ball joints, dust covers and EPAS water drain valve.
    Carry out road test.
    Re-set service interval indicator.
    Reset engine oil level indicator.
    Endorse service record.
    Report any unusual features of vehicle condition and additional work required.
    Labour cost included in scheduled time except items marked *
    If fault lamp(s) are illuminated, interrogate that system using the JLR approved diagnostic equipment and report findings.*
    Top up DEF tank.*
    Drain the DEF tank if the vehicle has covered less than 16,000 miles (26,000 km) in 2 years.*
  • Blackbeltbob
    Thanks for the details however to keep sane I shall keep what HTS said in my head Rolling with laughter Rolling with laughter
    Had the 2nd year service last week and no mention of air con or any additional charge.
  • Blackbeltbob
    So my cars better than yours Rolling with laughter Rolling with laughter
    Only kidding as I can assure you it probably isnt.
    It just goes to show how inconsistent the dealers are! Thumbs Up
  • Simon S
    Road test... ugghhh I hate the idea of a road test done as part of a service. I don’t want them driving my car Sad Big Cry
    Simon S
  • DiscoJack
    Sweden
    2017 Discovery Sd4 (180) SE Indus Silver
    I just bought a 2017 Disco 5 and think it needs to have its AC system regassed.
    The reason for this is a bad smell (Urine esk) when the AC is on, coolness and airflow seem good, I'm pretty new to car maintenance so would appreciate any tips if it needs regassing or just a general disinfectant / new filters.
    Also any tips for getting rid of the smell without costly expense.
