The full screen left to right is now occupied, and you get more vertical area because the menu buttons are on the driver's side instead of the bottom. The area to the right where the clock is also shows other info when in maps or music screen - in maps, it shows a music tab. I believe in music it will show nav info but I'm not sure. I'll get some more pictures tomorrow.
It was just an update to the Android Auto app on my phone - normal update as far as I can tell. I'm still on 18C on ICTP
What version of the Android Auto app is installed on your phone? It looks like the latest version here in the UK is 4.0.590434 and was released on 15th Feb, so you've probably got an update over there that hasn't rolled out here yet.
You might have to enable 'Developer settings' to get the widescreen output to work.
To enable the hidden 'Developer settings' do the following:
- Open the Android Auto App on your phone
- Chose 'About' from the top left menu.
- Tap the 'About Android Auto' text at the top about 10x
- You will see a prompt to enable Developer mode.
- Now use the top right ellipsis overflow menu to get to Developer settings
- Select the 1080p option
