- ossrider
Hi, I have just placed a thread in general regarding all terrains on 19's as the original fit are 255/60R19. We had 255/55R19 on our previous D4 and I have been trying to find a 255/60 profile. It looks form this thread that others have just fitted 255/55? Is this the way to go? What if any issues are there with that?
Any advice is appreciated, thank you
- harrythespider
Fitting tyres with a different aspect ratio to the originals whilst retaining the same diameter and width will without doubt affect the speedometer readings either higher or lower totally relative to the side wall height (aspect ratio difference).
What you need to do is google tyre comparison sizes and then decide which way to go, but ideally retain the same circumference,
You will find that if you compare JLR's different tyre combinations, that no matter what diameter you choose, the circumferences will all be similar.
If you wish to fit 19" rims then to retain the same circumference you could fit, if available, 275-55-19.
that gives a difference of just .44%, it is generally accepted that you can differ by up to 2.5% so there is room to accommodate variations.
I have 275 55 20 AT3's fitted to 47 offset rims and do not experience any problems. see my photo posted with them fitted.
I hope this helps
- harrythespider
osssrider.. That's why I went for 20's.
- sabljar
A note that Goodyear Wrangler Duratrac now have the 255/65R19, that I hear is used by the new Defender. Similarly Goodyear Wranger All Terrain Adventure also come in the same size of 255/65R19.
As the D5 "special offroad edition" was coming with a 275/55R20, which size wise is almost the same it "should" fit. I am considering in getting one of them soon.
- leeloo
I am considering ordering a D5 and I have a question. Can you fit 19 inch wheels on a P360 ? On the configuration they are not listed as an option, the online manual does mention them as a winter tyre/rim combo. Are they mentioned anywhere as a possibility for this specific engine ? I know for sure 18 will not clear the brake disks, but I would feel more comfortable having 19, every bit of sidewall helps at off road.
- al3jeel
Goodyear wrangler - defender black 19 wheels With extra spacer
- MAPMA
What's the size of those? 255/65R19?
- MAPMA
I'm considering that size but they're a bit bigger in diameter than the OEM ones. Any issue with clearance in access height when locking the steering wheel to the right or left?
