- petet
remote always correct location (even if it takes a few seconds to update sometimes having not contacted car for a while).. Tried signing in and out of all the different LR websites both on phone and desktop and planner persists in claiming the car is 2 miles away when it is sat outside the window. Something not joined up somewhere!
- chaos_theory
So that's an App issue rather than car connectivity issue. Sounds like a call to LR support.
Andrew
- petet
Thanks Andrew, since not really an issue with the car, I haven't worried about it, although I did report it to the dealer.. These gimmicks if provided ought to work and I see others have experienced the problem. Will have a chase when I've got nothing better to do. Pete
- MalithS
Re: First 500 mile niggles
chaos_theory wrote:
Before this sounds like just a rant, I need to say the car is just fantastic to drive - absolutely no quibbles with that. I am still trying to find my way around the various features so some of this may be me rather than the car:
5. Usual intermittent success with the gesture boot opening. Have also gone through a patch of it only opening part way through either the fob button or the tailgate button. And the flap refused to fold away once
Check out the video below for correct gesture tailgate opration and make sure its a 'kick' gesture not a 'swipe' movement. Once you get this right it works most of the time:
