  • frwamati
    Austria
    2017 Discovery TDV6 HSE Santorini Black
    Additional Lights - Lazer Lamps Wiring
    Hi Guys,
    I have purchased the Lazer Lamps ST4 Kit for the Disco 5.
    Since they are street legal i want to activate them parallel to the Hi Beams of the standard lamp assembly.
    Now here is my question:
    There is a fuse box located on the passenger side (EU Car) with fuses for the fog lights, etc....
    Where can i get my supply for the lazer lamp activation? Main power is connected directly to the battery anyway - its just about the feed that will kick in the relais for the ST4 lights?
  • Cradgebank
    You can take a relay switch feed from the Brown + Blue wire on the left headlamp plug or the Blue + Green wire on the Right headlamp.
  • JackNorris
    Let’s get some before, during and after installation images 🤓
    Check out this thread...alternate option but a wireless switch might be easier:
    https://disco5.co.uk/forum/thread1773.html
  • fmb123
    Re: Additional Lights - Lazer Lamps Wiring
    frwamati wrote:
    Hi Guys,
    Did you end up installing these? Could you provide details/photos of the wiring - are you able to wire them straight to the main beam signal at the back of the headlights?
    just about to order a set but hoping to avoid having to use the CAN interface.
  • ghost
    Norway
    Where are people drawing their main power from when adding auxiliary lamps?
