- frwamati
Additional Lights - Lazer Lamps Wiring
Hi Guys,
I have purchased the Lazer Lamps ST4 Kit for the Disco 5.
Since they are street legal i want to activate them parallel to the Hi Beams of the standard lamp assembly.
Now here is my question:
There is a fuse box located on the passenger side (EU Car) with fuses for the fog lights, etc....
Where can i get my supply for the lazer lamp activation? Main power is connected directly to the battery anyway - its just about the feed that will kick in the relais for the ST4 lights?
- Cradgebank
You can take a relay switch feed from the Brown + Blue wire on the left headlamp plug or the Blue + Green wire on the Right headlamp.
- JackNorris
Let’s get some before, during and after installation images 🤓
- DieselRanger
- fmb123
Re: Additional Lights - Lazer Lamps Wiring
frwamati wrote:
Hi Guys,
Did you end up installing these? Could you provide details/photos of the wiring - are you able to wire them straight to the main beam signal at the back of the headlights?
just about to order a set but hoping to avoid having to use the CAN interface.
- ghost
Where are people drawing their main power from when adding auxiliary lamps?
