  • rasko
    Azerbaijan
    2017 Discovery Si6 HSE Santorini Black
    AEB and LDW not available
    After replacement of the windscreen and the AEB camera calibration of IPMA passed successfuly, but now getting an error message: AEB and LDW not available. Anybody know how solve this issue?
    P.S. I have JLR original VCI and Pathfinder software.
    Have you checked that the Lane Departure Warning, and AEB has not been switched off, or reset itself?
    Is it an MY17 you have, or an MY18 onwards?
    You can access the settings in the menu, from the left side stalk, if you have the digital dash. (MY18 onwards).
    Am not sure how you would access the menu if you have the analogue dash though? (MY17).
  • rasko
    Azerbaijan
    Dear Road Runner 2017,
    Yes, i have MY17 car with analog dash. On left side of panel availible sensor switch to activate LDW. But no effect when push on switch, also if from menu switch OFF AEB i can not ON again, need set ignition OFF and ON.. Many information about thats issue but no any solution.
    I suppose you need a software update or at least a re-install.
    Mine had it as well and that’s what solved it, but have a MY18
  • rasko
    Azerbaijan
    Dear Labbix,
    I checked software via Pathfinder, it is latest version.
    I think for dynamic calibration need special place, will try do it this weekend outside of the city where road with road lines are better.
    Ok, good luck as I have no idea otherwise...
    Same as Labbix,
    MY18, software update sorted it.
    Had same issues AEB not available etc.
    Not sure if the MY17 needs additional updates or patches.
    A trip to the dealers am afraid. Keep us updated Thumbs Up
  • rasko
    Azerbaijan
    Thank you all for your comments and suggestions. The problem was that on factory settings the mark points for AEB plastic frame on the windscreen was indicated wrongly. After manually moving down for about 1 cm and after calibrating successfuly the AEB system was activated and all system errors disappeared. Thanks once again for help and if someone meets the same problem should consider this issue and there are many requests on the web about it and no solution by far.
    P.S. the JLR original windscreen was around $2000 in my country with import, taxes and installation. And Chinese costed me $200 all included and no difference accept this problem.
    Good to hear you have it sorted!
    One remark regarding the non-genuine windscreen; I was always told to stick with the original ones because of the working of the airbags, specifically the passenger one. As the windscreen is supposedly tested to withstand the impact of the airbags if deployed. With the non-genuine windscreen this cooperation is not guaranteed. This info came not from JLR, but from Volvo.
