  • Hessel
    2020 Discovery SDV6 HSE Lux Santorini Black
    Software 19B now available.
    Just had 19B down loaded this morning OTA.
    So far seems a lot more responsive.
    Only glitch is live apps have now disappeared. But I’m not worried as I find them useless. ACP works a dream. Other then that can’t find any new features. Also the 4x4 info now works as last update the four shocks never moved and was showing all grey that seems to be now fixed.🙏
    Not appeared for the Velar yet apart from a few in Germany.
  • TechnoTurkey
    Mine is still on 19A and says no update available Sad
  • PaulP
    Spain
    I've taken mine in today for it's first service and they will update the InControl Pro system (and add the Smartphone pack).
    They confirmed that the latest Pathfinder update is now showing S19B (dated 17/09/2019)
    Hessel, has your car been in previously to enable OTA?
  • bammmy
    Hello,
    My car did the previous update via OTA, but it’s currently saying no update available. Any thoughts???
    Mark
  • Chopsy
    Mine is the same. I assume the update is rolled out gradually?
    must book it in to have OTA turned on....dreading the experience already
  • TechnoTurkey
    Same here
    Popped in past the garage this afternoon, and booked in for the 19b update next Monday.
  • Big Al
    So is 18B OTA or not?
    I’ve supposedly had up the various updates to enable OTA but nothing!
    Hessel, are you sure about this:
    >>Also the 4x4 info now works as last update the four shocks never moved and was showing all grey that seems to be now fixed.🙏 <<
    With me it’s still as grey as grey can be, and nothing moves, only the diff lock that goes orange. Like the shocks should do as well, but still not with my car!
    19B is available on SOTA yes. But it seems some see it and some don’t. Worth double checking SOTA is actually enabled on your D5 as LR had issues activating it for a while, Can be done remotely too (the activation) so no real need for a dealer visit.
  • bammmy
    How can you see if it’s switched on, I did have now not so sure😳
  • Chopsy
    Main screen / settings / general settings / software update. Only problem is that it only shows if it is enabled in your car, not at Land Rovers end.
