  • aaddrryyss
    Romania
    DieselRanger wrote:
    I think LR's traction control is more intelligent than a mid-2K's pure viscous coupling. They reduce throttle and let the brake lock on the spinning wheel and then gradually let power back on once the traction has been established. Once the torque path is established it's not 1:1 power transfer left to right any more.
    I still wager that unless you're climbing Ben Nevis on a daily basis the wear due to traction control and grit in off-road situations is going to be orders of magnitude less than the wear due to brake-biased cornering assistance and just keeping the big brute pointed straight in daily motorway driving, if only because of the ratio of time spent in one situation vs. the other.
    ...only reporting from experience...
    I attached some photos for reference. You can see what the suspension needed to do, what the car was navigating through and the muddy view form the interior of the cockpit (in two flavors...plain_muddy and snow_muddy...with a tractor pulling, to mark the end of a sour day Twisted Evil )
    On the day these images were taken, the rear brake pads were about 6000 km "old". They were original Land Rover parts. I reached home with deep grooves in the steel of my rear brake rotors, caused by metal_on_metal friction. The brake pad material was...well...nonexistent at that point.
    The dash did illuminate warning about the brake pads reaching the end of their usable lifetime, but I was like..."well...and what do you want me to do, given the circumstances...??? Shut up and keep terrain_responding..."
    I really do believe a rear locker would have been a helpful addition at that point.
    L.E. the posted images don't seem to appear, although "uploading to server" did reach 100% and reported success.
    I'm pretty new around here, I'll go back to the basics and read terms and conditions and see if there's something I may have missed about permissions and whatnot.
    Later LE: There seems to be no restriction for me to upload photos. I used Firefox originally (under Windows10). Tried Chrome and behavior changes a bit, it goes to 100% and then says Error uploading to gallery. Out of ideas...
    Even later LE: thanks Labbix, pics finally went through, following your advice.
    Lower quality of pics, less MB should do the trick! Or sometimes try to upload again the next day...
    Once uploaded you still have to select the pics you want, at least in the mobile version (I almost don’t use the website version, only my phone).
    I was picking the LR instructor's brains yesterday, with regards to the rear locking diff.
    Is it worth it for someone like me??
    In a nutshell, no !!
    The car is more than capable without it, just using the various settings, rock, gravel, mud etc, for normal, light too medium offroading,
    However if your into serious off roading or your daily towing a maxxed out trailer full of livestock uphill, through muddy fields, deep water and rocky terrain, then it will definitely be an advantage.
    Everyday driving for Joe Bloggs, cars more than capable, but for Farmer Giles, it may well be a life saver, and worth its weight in gold.
    Incidentally the rear diff on the car we were taking around the course was making a hell of banging noise. Appears it had got damaged recently somehow, and was the first one that they have had damaged he said. It's still working fine he assured me Laughing
    interesting, I know of 2 ex LRE Scotland cars, one of which had a banging rear diff too.....and JLR declined to replace the rear diff saying there wasn't anything wrong with it.
    Good video
  • gavinadams
    Did my LRE day today west of Sydney.
    I also spec’d the car with the capability plus pack.
    So have terrain response 2, All terrain progress control & rear diff.
    On a steep climb in the national park, turned on the ATPC for about 5kmph.
    Just steered it up the incline effortlessly. Ok so takes the fun out of it but wow amazing tech.
    I too was quizzing the instructors on the difference by have the rear locker.
    So for what we did today probably not too much of a difference.
    It was interesting to watching the 4x4i screen for when the rear lock was working.
    Instructor said basically brakes will work harder if you do not have the rear diff, when it’s needed.
    My D4 didn't have a rear locking diff, my D5 has. Whilst it's not quite a like for like comparison, I've used them both on the same tracks quite a few times and where you could hear the D4 using the brakes for traction control, the D5 just cruises along effortlessly. I've very rarely noticed the D5 using the brakes to limit wheel slip.
    What I haven't done though is taken the D5 anywhere that the D4 got stuck. The only times I've had the D4 stuck was in deep snow and we've not had any similar conditions last winter so I haven't had chance to drive the D5 in snow yet.
    What is interesting is to see how much the D5 makes use of the locking diff even during normal road driving, I can't help wondering why it bothers to use it at all on tarmac.
    For safety: see more here @ end of video on the skid track (Gerotek = LR off road experience place as well)
    Well funnily enough that's what the trainer told me too. They reported it too the LR garage and
    they told them it's fine, and just keep driving it until it breaks, then it will get replaced Shocked
    I forgot to mention the instructor told me that they are also replacing brake pads at around 4k on cars with the rear locker, but without the rear diff replacing at 2k.
    (I think I have that the right way around. Was alot of techie stuff I was getting told).
    Strange, as with a rear diff lock there should be less brake pad usage...
    Ah, now it makes sense Wink but still VERY early to change the pads...
    Was an average of 4.5k to be exact.
    Yes I thought that too, but the cars must take one hell of a beating, as the tracks are very steep, especially downhill.
    Tried getting a full day, but so much demand, as they are so busy. Not to mention all the small stones and grit and debris getting caught up between the pads when transversing the deep water areas, damaging the pads and rotors.
    So it's understandable that the cars are munching through the pads Laughing
    That does look like an extreme situation, would think there would be plenty of opportunity for grit and small stones to get caught between the pad and rotors such that you're always picking up new grit and sweeping it between the pad and rotor over the rotor surface even if you're not using the brakes. Recall also the D4 is about 800lbs heavier than the D5, so that's a lot more mass to slow down even when you're moving slowly, so any application of brakes results in pressing the grit hard against the rotor and pad surface, and it's is going to cause issues if you do it long enough and don't have "clean" water to drive through to wash the pads and rotors.
    A rear locker certainly would have made driving through that muck easier. If you do it regularly, I'd say that you're going to get a ton of wear no matter whether you have a rear locker or not. But the D5 with a center locker, low range, mud/ruts mode, and ESC off can handle that without much drama.
    I think they also use the HDC on all of their downhills, which is all brakes. I, for one, always turn mine off - if it's steep enough to use the HDC, then it's steep enough to engage the low range, put it in manual mode, and let the engine and transfer box do the work. In 1st gear, anything that doesn't require my left foot bracing me back in my seat requires me to actually use the accelerator to move it downhill.
    Yes we were using the hill descent control mostly on the downhill parts.
    Just a pity, as I would have liked to have tried the more demanding parts of the course, without the rear locker engaged, just to see that difference, but the car made easy work with the diff lock engaged.
    Was a really good day with lots of informative stuff, and really appreciate what the cars full potential is Thumbs Up
