- Ecosse
Where is the SIM card located in the Disco 5?, is it micro or nano sized?
- Wolfpack
Under the central armrest in cubby hole. Think it’s a micro sim...but you get both from provider.
- marvin
- eelpout
anyone tried to put in a nano sized SIM? Unfortunately, Google for their data Fi service only puts out that size, no micro. I have an adapter (with a sticky surface), but it doesn't want to click in and seat in the D5 slot.
I've since found a bulletin (SSM73302) that says don't use anything other than a micro because they've run into issues with the adapters and cards getting stuck. (I've seen that happen with phones, not good
) Though there is a note that mentions using adapters with adhesive backing (though they aren't more specific than that). that's what I believe I have but still it won't "latch." Guess I'll just give up and stick with my AT&T micro.
