  • grabar
    instument cluster
    hi, has anyone managed, or looked into replacing the normal instrument cluster on MY2017, for a TFT digital dash, its something I am thinking of doing.
    unfortunately my 2017 only has the standard dash, and when I bought it 3 month ago it was not something I was bothered about, but now I am considering trying to fit one, if its worth the effort Very Happy
    You’ll have more luck picking the winning lottery numbers tbh. There’s so many issues with wiring, modules, editing CCF files, that I’d say it would be impossible to do.
  • karmax
    Switzerland
    The problem is that it is impossible to retrofit the digidash from my18 - it does not work to its full (since they changed something in body control module and some coding of can bus changed). I tried in vain. but the digi dash from rr sport 2017 fits well as it were designed for the disco (taking into account lots of if not all the modules coming from RR). But you need to keep in mind the following - indecently high cost of the dash and cable to connect it to the icm (to have full screen Navi), and cost of retrofitting and programming. Mine turned to 1700 euro for the dash and 300 euro for the fitting.
  • Cal2627
    2017 Discovery Si6 First Edition Namib Orange
    TFT install 2017 First Edition
    Karmax,
    This is something I’m really interested in doing. Can I get some info from you on where to start?
    Thanks for any help
