  • al cope
    Roof Rail fitting
    Following ion from posts in one of the other threads, here are some pics and tips from me fitting the roof rails. These are Genuine LR rails with Ditch finishers (all from Dan @ Duckworths). I went for the genuine items as the rails generally on fleebay dont come with the ditch finishers, and front fitting in the cheap ones looks like it might be plastic, whereas the LR one is metal.
    So, here goes:
    3 boxes of parts
    Tools needed - T40 Torx bit, some plastic trim tools, and a hair dryer (the paint brush is just to brush any bits/dust out from under the old rails once removed) Whistle
    Use the trim tools to remove the existing plastic covers - this is the front one just taken off, but you then have to remove the plastic bits you can see - these are fixed with double sided tape:
    Take the 6 bolts out that you find under the trim:
    And here is a back one off:
    You will find sticky pads and 3M tape as well as clips have been used to hold the exiting trim on. I found the hairdryer was the best thing to get the sticky off, and then some surgical spirit, as the 2 3M cleaning pads supplied are so small that wont clean very much at all. Cleaned front bits here:
    Once all clean you can start fitting the new ditch finisher trims - do the front long one first, getting the front edge under the rubber windscreen trim.
    Then do the back one. A tip here is ignore the order in which you clip the trim down on the LR fitting guide. I did this and bent the back inner clip, but you can't then get to it easily as the 3M tape has grabbed. For the second side I just started with the rear 2 clips and worked forward - much easier.
    here is the ditch trim fitted:
    Once this is done you fit the very front fixings, they are handed (L & R) so check, as here:
    Then fit the ruber trims to the rear part of the rails (just pushes on) and then fit the rails, 2 loose bolts (supplied) at the front, 4 captive (by the seals) at the rear.
    tighten up to the spec'd torque, and then fit the bolt covers - and you're done for that one:
    Then go do the other one - same process - took me about an hour and half, was taking it slowly.
    Finished job:
    And finally - I was hoping to keep the parts I'd removed in case I wanted to take the rails back off, but Russ had commented about the platic parts used to fit them being brittle and breaking - he was right, so whilst I have the glossy bits the bits underneath are in peices and in the bin.
    Hope this helps
  • TechnoTurkey
    Really helpful and something I intend to do this year, may I ask how much the genuine set cost you?
  • al cope
    £454 inc shipping from Dan
    Think you can get new clips
  • Looneyfitter
    You got a contact for Dan mate?
  • al cope
    They are one of the site sponsors so you should be able to PM Dan, but here you go:
    My Direct Line: 01673 849873
    Email: danroberts@duckworthlandrover.co.uk
    Website: www.duckworthparts.co.uk
  • RiverBlanche
    good write up Thumbs Up and always good to have pictures Wink
  • TechnoTurkey
    Just done mine, thank you for the pictures - in conjunction with the instructions you really don't need anything else Thumbs Up
    Also took me around an hour and a half.
  • B50int
    Mine done too. Great write up, really takes the guess work out for the first one! That took about 45 mins. I did note that the old bolts that are discarded are T40, but the new ones are T45.
    Second one was very straightforward and only took about 20mins.
    Thanks for tip on the rear ditch finisher fitting order. Worked a treat and can’t see the logic for the LR instructions order of fitting.
    Jon
  • globalste
    Al, can I ask which side steps/running boards you have there? They're quite nice looking, any other photos of them?
  • BruceT
    South Africa
    I recently removed mine as I fitted a roof rack. One of the most important things is to make sure the seals are correctly seated to the mounting brackets that connect to the roof. If not you will have leaks.
  • hocks172
    Ill be trying to fit these to mine this week as soon as they arrive. Cant wait to see what they look like.
    No more Landrover!!!
    Previous LR: D3 HSE, RRS HST, Evoque Dynamic Lux, D5 HSE LUX.
    Global if you do a search on here using keyword sidestep, you’ll find a few photos and fitting instructions. I’ve got the same as Al. Very good quality.
    In fact found the thread,
    https://disco5.co.uk/forum/thread1490.html?highlight=Sidesteps
  • BigCol66
    Roof Rails
    Fitted a set today thanks to Al's guide. Worst thing was getting the sticky residue off from the original ditch finishers.
  • Ianpettifer
    Is this company still operating? I need to buy some rails and cross bars asap for a holiday in 3 weeks time for my disco5. HELP?
