  • StinTov
    ICTP S20a is coming
    S20A is in final testing and should be released within a week or two. Spotify will be baked in apparently!
    Oh no!! That means another round of debugging will be called for by us beta testers. Whistle
    wonder if it puts back things that currently haven't worked in 18D and 19....probably fixes some and removes others!
  • JamesMcBride
    Probably a stupid question (I'm new here Smile), does it need to go in to a dealer to have this updated?
    If you have Over The Air ( OTA ) updates enabled by JLR for you VIN then it should be available to download at some point.
    What version are you running at the moment?
  • JamesMcBride
    Thanks will check!
  • rsr
    Jim, is there a way of checking if OTA is enabled? Mine always says software up to date and shows 19b
    You need to contact the dealer and get him to check the "system" , if it has not been enabled then they can do it.
    I am meant to take the car in for a couple of updates including the Infortainment on Friday, 13th Match! Is that tempting fate? Shocked
    It is if they put on this new version! Rolling with laughter
    I blame SWMBO, the date was to suit her coming with me on her day off, she wanted to go shopping in Elgin. I mentioned it was Friday 13th and I got it in the neck for being “silly”
    These are all signs you know! Shocked
  • mb1
    2017 Discovery Si6 First Edition Farallon Black
    Is this what is showing up on the Defender gallery images? If so it looks much more appealing
  • Equilibrium
    Defender is the new Pivi Pro system, as far as I know that’s a different system vs Incontrol Pro.
  • StinTov
    So S20A_20.07.5-507626 is here
    So S20A_20.07.5-507626 is here. It bring Spotify and a load of fixes. You need to re-login to LiveApps to get the Spotify.
    Any significant differences spotted so far?
