StinTov
ICTP S20a is coming
S20A is in final testing and should be released within a week or two. Spotify will be baked in apparently!
jimbg
Oh no!! That means another round of debugging will be called for by us beta testers.
mordred1973
wonder if it puts back things that currently haven't worked in 18D and 19....probably fixes some and removes others!
JamesMcBride
Probably a stupid question (I'm new here
), does it need to go in to a dealer to have this updated?
jimbg
If you have Over The Air ( OTA ) updates enabled by JLR for you VIN then it should be available to download at some point.
What version are you running at the moment?
JamesMcBride
rsr
jimbg wrote: If you have Over The Air ( OTA ) updates enabled by JLR for you VIN then it should be available to download at some point.
Jim, is there a way of checking if OTA is enabled? Mine always says software up to date and shows 19b
jimbg
You need to contact the dealer and get him to check the "system" , if it has not been enabled then they can do it.
Dangerdave
I am meant to take the car in for a couple of updates including the Infortainment on Friday, 13th Match! Is that tempting fate?
jimbg
It is if they put on this new version!
Dangerdave
I blame SWMBO, the date was to suit her coming with me on her day off, she wanted to go shopping in Elgin. I mentioned it was Friday 13th and I got it in the neck for being “silly”
These are all signs you know!
mb1
Is this what is showing up on the Defender gallery images? If so it looks much more appealing
Equilibrium
Defender is the new Pivi Pro system, as far as I know that’s a different system vs Incontrol Pro.
StinTov
So S20A_20.07.5-507626 is here
So S20A_20.07.5-507626 is here. It bring Spotify and a load of fixes. You need to re-login to LiveApps to get the Spotify.
discus
Any significant differences spotted so far?
