No idea? There are 2 options, light load and heavy load
- B16 KJR
What part of the settings menu do you input that information to?
- Craigp
Yes TPM . So it knows if the tyre pressure has dropped any from the high set pressure (heavy) or the low set pressure. Forget the actual figures.
- Craigp
Steering wheel menu button. Or it is on the 4. I believe it only appears when stopped ie parked.
- stuart_f
Sorry. No review from me. My car is deader than a Dodo and not even the dealer can seem to revive it.
- pdes
Just back from our jaunt. I checked and re-checked the tyre pressures before the return journey. I also removed the fuse that according to the hand book was the feed for the ATC (pin 9 on the socket) but as we hitched up, the ATC still kicked in so I don't believe I managed to disable it.
Anyway, all seemed to be reasonably OK for the first few miles although Mrs PDES said that she could still feel some swaying. I, however, though that the problem had improved - until we were going downhill on the motorway and the swaying started. It got to a point where some automatic braking kicked in. I have to say, we nearly cacked ourselves. To have the swaying and then uncontrolled braking on a motorway is no fun!!
So we came home at no more than 55mph and all was well.
I had mailed my dealer on Friday with the details and asked him urgently to raise this up the line to whomsoever was appropriate and have chased this with him today, emphasizing in no uncertain terms just how serious this could be. I have also mailed Alko to try and get a dialogue going with someone in the know but Alko sees to be one of these companies that says "speak to the service rep". We all know what that means.
Anyway, just thought you would like an update. I think we need to keep this thread going until others have ventured out with their vans and can report back.
Series 1, 1953, 86"
- Russell
This is a little worrying as I toe a Swift elegance 645 which is similar to yours and with the D4 it towed really well. However I did have to keep the nose weight up at around 100 otherwise it was a little twitchy.
What nose weight are you running. Are you running with the on board water tank full or empty, and what tyre pressures are you running in the rears
There was a post ofn D3 forum a while back that said there was a delay in production due to towing issues, will see if I can find it
- pdes
Re: Process of elimination.
Road Runner 2017 wrote:
Glad you got back home safely mate. Yes I totally agree the consequences could have been a whole lot worse
Just a query, is it possible this could maybe be down too the type of towbar being used?
That is, have people gone for the electronically deployable tow ball, the detachable, or fixed-height adjustable one. Would be good too know what tow bars are being used. I know from previous years that the detachable had issues for failing and wear and tear and detaching totally from the tow bar as well as the electronically deployable one having issues also. I have always went for the fixed one as seems a far safer bet. Never had any problems. What's the point of aesthetic looks when in fact the product could seriously injure or kill someone.
I have the manual detachable tow ball. I ordered the auto one just as they ran out but didn't want to wait until May!
Series 1, 1953, 86"
- pdes
Not sure what the nose weight is but it can't be heavy as we left the awning at home (and it's twin axle)! One thing not to lose sight of is that this van towed perfectly with the D4.
Rears are 50psi. I ran them lower but didn't make any difference
Series 1, 1953, 86"
