  • merlintilly
    2017 Discovery Si6 HSE Lux Firenze Red
    Rear brake pad change
    Does anyone have a drawing or information about how to remove the rear brake pads? I have removed the usual two bolts but the D5 assembly is different. Big Cry
  • harrythespider
    Jack car up, put on axle stands, select neutral and release parking brake, switch off ignition and remove electrical connector from park brake wheel module, remove park brake motor. use torx to rotate park brake piston off. spread brake pads, remove caliper bolts and remove caliper. Do the same in reverse.
    before adjusting park brake , pump brake pedal a few times to bed pads,
  • merlintilly
    Thank you very much for the information and advise. Very Happy
    If you turn the ignition off wont the park brake come straight on
    Not if you hold the park brake lever / button down when powering off. Stops it auto engaging.
  • merlintilly
    Park brake adjustment
    How do you adjust the rear park brake after brake pad change?
  • al cope
    I didnt think you needed to any of that for just a rear pad change, I thought that was only for replacing the parking brake pads
  • merlintilly
    The park brake uses the rear brake pads. As per harrythespider post you have to back off the park brake mechanism to release the rear calliper carrier.
  • merlintilly
    How do you readjust the park brake after changing the rear brake pads?
  • STOAT
    Try this. Parking Brake Service Activation and Deactivation - Discovery/L462
    You will hear the park brake mechanism whirring - wait until that stops before you release the accelerator in steps 6. and 12. and a warning display on the dash will display if successfully activated.
    No need for adjustment.of the parking brake mechanism.
    Activation
    CAUTION: This procedure requires the vehicle in the Park or Neutral position, with the
    ignition turned ON (the engine must be OFF) and the parking brake system
    released.
    NOTE: This procedure allows the parking brake to be released when removing and
    installing new rear brake pads or brake discs.
    1. Press and hold the parking brake switch in the release position.
    2. Wait 2 seconds.
    3. Press and hold the accelerator pedal in the wide open throttle position.
    4. Wait 2 seconds.
    5. Turn the ignition Off and back On immediately.
    NOTE: An audible noise will be heard to confirm that the parking brake has been
    released in Service Mode.
    6. Release the accelerator pedal and release the parking brake switch to the neutral position.
    Deactivation
    with the ignition turned ON (the engine must be OFF) and the parking
    brake system in Service Mode.
    Once the rear brake pads or brake discs have been installed, the
    Service Mode must be cancelled.
    7. Press and hold the parking brake switch in the apply position.
    8. Wait 2 seconds.
    9. Press and hold the accelerator pedal in the wide open throttle position.
    10. Wait 2 seconds.
    11. Turn the ignition Off and back On immediately.
    released from the Service Mode.
    12. Release the accelerator pedal and release the parking brake switch to the neutral position.
    2017 D5 HSE Grey
