  • Johnson
    Belgium
    Apple CarPlay not available
    Hi all
    I had apple car play working fine (ie according to LR standards- some times better then others but overall OK)
    Since couple of weeks get the message “Apple car play not available“. Am on the latest SW, have unplugged and replugged with different cables
    Anyone encountered the same and/or has tips and tricks?
    Tx
    Koen
    Have you tried a restart/re-boot of your iPhone?
  • Darling
    What IPhone are you using, i went for a 6S which worked just fine to a XS and now its painful to get it working.
    D
  • Johnson
    Belgium
    Thanks for the replies
    -have rebooted the phone several times
    - I have an IPhone X (and have not changed phone)
    Koen
  • Blackfly
    do you have the most recent version of IOS?
  • Johnson
    Belgium
    I’m on the latest SW for the phone, tried with other phones in the family
    And the car is On the below SW version - think this is the latest
    [/img]
  • jungle42
    When my iPhone is not charged to at least 20%-30%, then CarPlay will not work correctly. It then loses connection and reconnects constantly every few minutes (or even seconds) which is quite annoying.
    If the phone is fully charged, no problems.
    It's an iPhone 11 Pro with original Apple Lightning cable.
    So for me the solution is to charge the phone before any longer journey. And if not, I use the other USB socket (without media) in the center console to charge the phone, but then I'll have listen to Spotity over Bluetooth...
    The only time Apple CarPlay didn't work for me was when I bought a shorter cable which wasn't Apple branded. Went back to an Apple cable and all is ok.
  • teaman
    Have you tried another USB port? Other than that confirm the settings on the Infotainment system for CarPlay and on iOS. Since iOS 13 security changes you need to unlock your phone to connect over USB (unless you change the settings).
    Would also go into CarPlay on iOS and remove the pairing - thus allowing you to pair it to the vehicle again (which might solve the issue).
