  • pdes
    Fuse sizes
    I need to find a switched power source for my dashcam. I have found the fuse that has the correct characteristics but didn't realize that the fuses in the D5 are smaller than the mini fuses in the D4 so the piggy-back adapter that I removed from the D4 fuse box won't fit! Does anyone know what these fuses are called so that I can search for an adapter.
    Failing that, has any one found a lead under the front dash that is ignition-switched and which I can tap in to? Trouble is, everything is so tightly packed, it's nigh-on impossible to find your way around under there Evil or Very Mad !!
    Series 1, 1953, 86"
  • Scrumps
    If the fuses are the same as my RRS2 - I haven't checked - then they are "micro 2" size.
    The guys on the RRsport forum use these:-
    http://www.co-star.co.uk/prod/4008/micro-2...older.html
    to piggy back off an existing circuit for a dash cam.
    Scrumps
  • pdes
    Cheers Scrumps. Bow down
    Series 1, 1953, 86"
