- pdes
Fuse sizes
I need to find a switched power source for my dashcam. I have found the fuse that has the correct characteristics but didn't realize that the fuses in the D5 are smaller than the mini fuses in the D4 so the piggy-back adapter that I removed from the D4 fuse box won't fit! Does anyone know what these fuses are called so that I can search for an adapter.
Failing that, has any one found a lead under the front dash that is ignition-switched and which I can tap in to? Trouble is, everything is so tightly packed, it's nigh-on impossible to find your way around under there
Series 1, 1953, 86"
- Scrumps
- pdes
Cheers Scrumps.
Series 1, 1953, 86"
