nebc100
Rear e diff oil change
Hello All,
My D5 has now done approx 45000km, and I want to do a diff oil change to make sure they are all good.
I have done it on the D3, RRS and D2 that I previously had, but I have not found a guide on here how to do it.
I have ordered the special oil since I have the rear e-diff, but can anyone tell me if it is a fill to overflow or purely on quantity?
If it is purely on quantity... How much do I put back in?
Thanks for your help.
Nick
STOAT
For E-Diff:
Its fill to base of filler hole.
Approx 1.2L Castrol BOT 720 fluid.
30nm to tighten both plugs.
2017 D5 HSE Grey
nebc100
Thanks!!
Are you sure that it is Fill to overflow?
Just that I read somewhere (but cannot find it) that it is Fill by Volume and not to overflow.
Does anyone by any chance the maintenance manual for this?
STOAT
It’s just a dribble from base of filler hole.
2017 D5 HSE Grey
nebc100
Ok... That is what I thought from when I did my D3, RRS and D2.
I was just concerned because I have read on the D3 site that for the e-diff it is by measurement and not just till it dribbles out.
Since I have not had a vehicle with the e-diff before, I wanted to check before making an expensive mistake.
STOAT
For your peace of mind from the manual:
2017 D5 HSE Grey
nebc100
Thanks!! That really put my mind at peace!!
mordred1973
2x fluid changes almost stopped my ediff thudding....
DieselRanger
Great info of the sort this forum is made for, thanks!
Any way to "sticky" this one?
