- eelpout
> Wi-Fi
hmm, I'll have to check my settings. honestly, it's never been that um, robust at switching between the cellular and Wi-Fi radios anyway. In my neighborhood with a gazillion access points, it spends more time searching for something to connect to than actually connected. Could be this hasn't gone unnoticed and they decided to disable it.
- 33Lurcher
Just got one downloaded and installed whilst out this morning .
2021 D250 S Eiger Grey HSW Privacy Hi/Low Ratio
- discus
To be honest, there doesn't seem to be much in the way of improvements and changes in the new releases. It's quite a powerful tool, and pretty cool that a car can update itself OTA, but it doesn't seem to be used to deliver any features, or even many fixes.
- mordred1973
think we also now need to be mindful, that with the new Disco having Pivi, any updates for our earlier ones will be purely bug fixes not improvements or new functionality.
- nebc100
I am not so worried about that.
The only thing that my D5 does NOT do that I miss is the Text to Speech when someone sends me an SMS.
Having said that... When I have seen the Pivi Pro on Youtube (for example in the PowerfullUK videos), I fond that the speed is certainly no better than on my D5.
Currently, I have also not had any bugs in my D5 system.
So long as they don't break anything... it can keep going as it is now.
- mordred1973
I have to admit, I wish the "old" system booted up quicker .....otherwise its alright, not too laggy when moving about menu's
- nebc100
If you think that it is bad now... you should have tried it 2 years ago when it was the OLD versions..... It was SLOW to start up then.
At least now you can access things REASONABLY quickly.
I used to have to wait and wait and wait before I could deploy the towbar. Now I can actually deploy it as soon as the car has started. That isn't too bad.
- mordred1973
I can't add a destination to the NAV or change radio station until about 300m down the road from a cold start....nor do anything else from the screen until then since even if it says "touch screen to continue" it doesn't react.
To deploy towbar at home, I usually have to use the button on the load area...wouldn't say mine boots up any quicker on 20C than it did on the old 4 tile software.
- nebc100
Strange... Mine is MUCH faster for startup on 20C than it was under the 19 series.
When I get the LANDROVER icon, I can press on the screen and it almost immediately goes to the main window, I can then start the navigation, and input my destination immediately.
- mordred1973
ah no mine is not like that at all
annoying....
- Equilibrium
Mine usually starts fast and into CarPlay in 10 seconds.
Except for the the 20% of time when it takes 90 seconds.
And except for the 5% of times when it needs the phone to be plugged and unplugged.
And further except for the 2% of times when it will never connect to the phone until the car is switched off for ten minutes.
- Darras
Or be like me and don’t switch the
thing on to start with, then it makes no difference if it’s updated or not.
- IndusD4
I have a late 2018 SE that does, but needed to be enabled on the phone. Although I don't think you miss anything as it's not that good, CarPlay is a little better but can't cope either when getting an SMS in Dutch,
- 33Lurcher
It’s on my 2021 model , needed to enable it on iPhone .
- nebc100
Sadly, I have a VERY early D5 and it does not support sms reading at all.
My wife's epace (same infotainment system) does support it, but not my D5.
Never mind... I am not so worried it is just that it would have been nice to be informed when an SMS comes in while I am driving.
