  • 747_JK
    Spot the difference (and an explanation would be good too!)
    Spotted a slight difference on the front of my Discovery... following a new front bumper being replaced recently.
    Not sure if these two components where the 'gap' is were replaced too, but I'm sure I never saw different sized "holes" either side before? The two parts left and right also look slightly different...
    Is there anything wrong here, or anything to worry about?
  • bammmy
    Hello,
    Just been and checked my 19 plate HSE and it looks the same as yours👍
    Mark
  • BBDisco5
    2022 Discovery SDV6 HSE Lux Carpathian Grey
    Here are mine (excuse the grime) Both look similar underneath.
    I can't see a difference on your two photo's?
  • Popsdosh
    Looking at the pictures I think when its been rebuilt they have not cut the piece of panel on the right . I believe the small piece should be removed to aid brake cooling.
    Its the piece in the top photo which if you cut out the small piece marked would then match the second picture.
  • 747_JK
    Thanks everyone - and yes, on mine it does look like there's a bit of extra plastic showing, And if @Popsdosh is right, it maybe should have been pushed off before fitting to make the gap larger for brake cooling.
    But then @bammy says theirs looks identical to mine... Really, with this extra piece showing on one side only?
    Highlighted below:
    [/img]
  • BBDisco5
    I see it now Thud
