- nebc100
Birdie in d5... Help - Exhaust pressure control valve
I'd guess it's a starling.
- nebc100
Thanks Jon, but this was in fact an honest question.
There is a strange squeak. It is not from the transmission as I could reproduce it when the car was stationary.
Doesn't always do it.
Throttle body was replaced today, but sound still there.
- Jones
Squeak!
Also bought a squeaking Discovery last year. To cut a long story short, yes brakes etc were checked etc , turned out it was the spare wheel! Had to be un wound and removed and grease applied to mechanism and problem completely solved and no more random squeaking !
- nebc100
Sadly not that... squeaks even when car is stationary.
- nebc100
Small update.
LR don't have time to take a look for the next 2 weeks, so went to a friendly independent garage that I know (not LR specialist!!).
They took a look immediately, and it seems that the issue is the exhaust pressure control valve.
So... at least it is not something critical, and can wait until the appointment that I have been given by LR so that it is covered under warranty.
Has anyone here had this issue?
Anyone know how much & how long that repair will take?
- nebc100
Latest update... Quote to sort this out is an eye watering €1800!!!!
Waiting to see if extended warranty will cover it.....
- Fer
Hello, in my case it started to make a kind of squeaking at times and in a few days it did so from the moment the engine was started, it was a noise like a bearing that has run out of grease, sometimes it sounded and sometimes it didn't. It was the fuel pump and they changed it under the used vehicle warranty. Excuse me for my English, I use a translator
- ThatMartinChap
When does it squeak when stationary ?. When the engine is running or after you have turned off the engine?
Mine also squeals when the engine has been running for a while, then turned off. It gives 3 or 4 short squeaks that you can hear after getting out of the car.
D5 D300 R-Dynamic HSE MY21
- nebc100
It squeaked when you "blipped" the throttle.
It only ever happened with the engine on because it was actually a valve on the exhaust that was opening & closing that was making the noise.
- ThatMartinChap
ok thanks. I'll try a couple of blips and see if it happens. But I definitely get it with engine off also, which suggests it is something different to what you had. To me, it sounds like an actuator of some sort that needs some lube.
