- Wolfpack
Traffic information not available
Having a bit of a brain fog.
When I am driving about I have the black half screen on the left with the above message.
When I arrive home and it picks up my home WIFi the left lights up with a greeting acknowledging I am logged in. So my car would appear not to be working off mobile data.
(My maps are up to date as is my subscription.)
I bought a data sim in the car, over a year now and wondering if it’s stopped working or just run out. Not sure how to check it?
It did work when I first installed it but with the restricted local only use during the pandemic I cannot say I noticed when it stopped working. Are data sims time limited?
Is this down to the data sim or would the cars onboard sim be handling this?
I am sure that the black half screen happens everywhere away from home …. so I am ruling out poor signal.
I was going to buy another data sim but before I do, are there any other points I am missing?
Thx
- Darras
Data sims are time limited. Mine with 3 was two years. I didn’t run out of data, just time, so purchased a new one and it was fine.
- al cope
Also, just try turning mobile data off and back on again and see if it picks up the info, try that first. Mine would occasionally do that.
- Wolfpack
Thanks guys
I suspect I may be over my 24month limit. Time flies when you are having fun.
But I will switch off/on mobile data to double check.
- Duckers
Hi Guys
I am having the same problem with the navigation, works OK on WiFi but not via the SIM
Assuming my SIM has expired (MY2019) What SIM card do I need and is it plug and play or which settings need to be adjusted,
Thanks in advance
K
- Wolfpack
- Duckers
Thanks for the update
Much appreciated
K
