    Traffic information not available
    Having a bit of a brain fog.
    When I am driving about I have the black half screen on the left with the above message.
    When I arrive home and it picks up my home WIFi the left lights up with a greeting acknowledging I am logged in. So my car would appear not to be working off mobile data.
    (My maps are up to date as is my subscription.)
    I bought a data sim in the car, over a year now and wondering if it’s stopped working or just run out. Not sure how to check it?
    It did work when I first installed it but with the restricted local only use during the pandemic I cannot say I noticed when it stopped working. Are data sims time limited?
    Is this down to the data sim or would the cars onboard sim be handling this?
    I am sure that the black half screen happens everywhere away from home …. so I am ruling out poor signal.
    I was going to buy another data sim but before I do, are there any other points I am missing?
    Thx
    Data sims are time limited. Mine with 3 was two years. I didn’t run out of data, just time, so purchased a new one and it was fine.
  • al cope
    Also, just try turning mobile data off and back on again and see if it picks up the info, try that first. Mine would occasionally do that.
    Thanks guys
    I suspect I may be over my 24month limit. Time flies when you are having fun. Rolling Eyes
    But I will switch off/on mobile data to double check.
  • Duckers
    Hi Guys
    I am having the same problem with the navigation, works OK on WiFi but not via the SIM
    Assuming my SIM has expired (MY2019) What SIM card do I need and is it plug and play or which settings need to be adjusted,
    Thanks in advance
    K
    I got a Three 24 GB, 24 month pay as you sim
    Once I put it in the right way round Rolling Eyes and switched on the mobile data in connectivity menu option, it worked ok.
    Here’s an example…
    https://www.amazon.co.uk/Three-Mobile-Pay-...&psc=1
  • Duckers
    Thanks for the update
    Much appreciated
    K
