- Beancounter_74
Heated Steering Wheel and Remote Fault
Hello
Recently picked up a MY2019 Discovery HSE Lux, love it, but a couple of niggles.
One of the remotes works perfectly regarding the keyless access, the other only operates as a remote and starts the car. Changed the battery (a couple of times for a new one) and doesn't fix it - any ideas?
Also, the heated steering wheel was fine when I collected the car, but seems to have stopped working, the light comes on, but doesn't heat up - again, anyone know the fuse number I can check or had the same?
Obviously, I'll be chatting to LR where I got it from, but just wondered if either was an easy fix.
Thank in advance
- Beancounter_74
Bit lonely in here
Anyway, fixed the heated steering wheel, Fuse 43 behind the glovebox. Car has had a dashcam previously fitted and they've used that as a jumper for it and it had become dislodged, so just the duff remote keyless access to sort now.
Anyone got any ideas?
- 747_JK
I do diesel, AdBlue, screenwash and air. If it's not one of those, then it's too technical and I need the dealership... sorry! But glad to hear you got it sorted! Enjoy your D5 ownership! And do post some pics, would love to see your motor...
- Beancounter_74
Popped a new car thread up with a few pics
