  • PeterW
    Off road settings
    Hi all.
    Whilst in Auto terrain response mode (Auto knob pressed down). I stop put car into neutral, then select low range, BUT this also puts car into Off road height & turns on HDC.
    Is this to be expected?
    Edit Can someone move this post to the Off Road section please
    Peter
    HSE 3.0 V6 Diesel Corris Grey
  • Scrumps
    Peter,
    Having spent Monday at Eastnor in an RRS2, I'd say that's correct.
    IIRC to use just low range you need to dis-engage the auto terrain control by pushing the knob down and allowing it to pop-up.
    I'll be trying it on ours this weekend as I always run all three of our Landy's a short distance in low box once a month to make sure nothing seizes up.
    Scrumps
  • PeterW
    Thanks Scrumps can see the logic of Off road height although not HDC, will disengage Auto & check mine. keep me posted on your findings please.
    Peter
  • PeterW
    Scrumps wrote:
    Peter,
    Scrumps
    Yes as you said. Thumbs Up but HDC also comes on
    Peter
  • stuart_f
    Peter - the behaviour you are seeing is the way the Disco 5 at the Land Rover offroad driving school behaved. HDC comes on by default when low range is selected.
