- PeterW
Off road settings
Hi all.
Whilst in Auto terrain response mode (Auto knob pressed down). I stop put car into neutral, then select low range, BUT this also puts car into Off road height & turns on HDC.
Is this to be expected?
Edit Can someone move this post to the Off Road section please
Peter
HSE 3.0 V6 Diesel Corris Grey
- Scrumps
Peter,
Having spent Monday at Eastnor in an RRS2, I'd say that's correct.
IIRC to use just low range you need to dis-engage the auto terrain control by pushing the knob down and allowing it to pop-up.
I'll be trying it on ours this weekend as I always run all three of our Landy's a short distance in low box once a month to make sure nothing seizes up.
Scrumps
- PeterW
Thanks Scrumps can see the logic of Off road height although not HDC, will disengage Auto & check mine. keep me posted on your findings please.
Peter
- PeterW
Scrumps wrote:
Peter,
Scrumps
Yes as you said. but HDC also comes on
Peter
- stuart_f
Peter - the behaviour you are seeing is the way the Disco 5 at the Land Rover offroad driving school behaved. HDC comes on by default when low range is selected.
