      - techzz
      rear quarter light
      Hi all, trying to find a link on how to replace rear quarter brake light on Discovery 5 2019 any help greatly appreciated
      - zig
      iGUIDE is not much help (search for “bulb”) under the heading “CHANGING A BULB” all it states is:
All lights that are either LED or xenon units must only be replaced by a retailer/authorised repairer.
Before attempting a bulb change, make sure the ignition and the affected light are switched off.
Always replace bulbs with the correct type and specification. If in any doubt, contact a retailer/authorised repairer for advice.
However, it should be noted that there is a “BULB CHECK“ feature.
      - techzz
      can't change bulbs as LED's but have sourced a replacement unit but can't find how to remove existing light
      - zig
      - techzz
      - thrillernight
      Yeah those LED units can be a pain to replace.
