  • techzz
    rear quarter light
    Hi all, trying to find a link on how to replace rear quarter brake light on Discovery 5 2019 any help greatly appreciated
  • zig
    iGUIDE is not much help (search for “bulb”) under the heading “CHANGING A BULB” all it states is:
    All lights that are either LED or xenon units must only be replaced by a retailer/authorised repairer.
    Before attempting a bulb change, make sure the ignition and the affected light are switched off.
    Always replace bulbs with the correct type and specification. If in any doubt, contact a retailer/authorised repairer for advice.
    However, it should be noted that there is a “BULB CHECK“ feature.
  • techzz
    can't change bulbs as LED's but have sourced a replacement unit but can't find how to remove existing light
  • zig
    See files attached to https://landroverforums.com/forum/new-disc...-a-110246/ which hopefully will help you
  • techzz
    thats great thanks
  • thrillernight
    Yeah those LED units can be a pain to replace.
