  • Scwede
    Sweden
    2017 Discovery Td6 First Edition Farallon Black
    Engine Failure?
    Owned it for 3 weeks...
    At 120kph I got "Reduced performance" for a few seconds and then "Engine System Failure/ Fault" and it cut out.
    Won't restart, simply spins.
    I did point out that the something was off when I bought it - like a rumbling wheel bearing - dealer diagnosed a dry auxiliary belt/ bad tensioner (still to be changed) but now it's dead...
    Haven't had an official diagnosis yet. Any depressing suggestions, let's hear them Smile
    What engine?
    How many miles/ km?
  • Scwede
    Sweden
    TDV6 at 155K km (96K miles) - full main dealer service history...
    TDV6 First Edition
  • 747_JK
    Really sorry to hear that, and can feel your frustration. Hopefully there's some sort of warranty coverage on the car still?
  • harrythespider
    Be optimistic ! at least if the engine spins over it won't be the crankshaft, I would be hoping its the rear belt . Being a TDV6 its probably at the age when both belts should have been changed,
  • Scwede
    Sweden
    Thanks Harry,
    A good point.
    I'm not able to read the codes as it's waiting to be diagnosed - the service history shows that the cambelt service (both belts we would assume) was done 8 months ago, but you never know.
    For now the sport is speculation Smile.
    TDV6 First Edition
    They can a do spin over even with a broken crank but are noisy
  • Scwede
    Sweden
    An update,
    It has taken a while for the garage to diagnose it bit they think it's the low pressure fuel pump.
    Seems a little strange as no symptoms before absolute failure.
    But we will see...
    TDV6 First Edition
  • JBFUK
    How's it going?
    Any update
    From what you've mentioned...I'd suspect the fuel timing belt, or rather the noisy pulley/tensioner you described has seized or dropped possibly (at a stretch) causing the belt to jump a tooth after the bearings failed. Perhaps the timing belts were indeed replaced but without replacing the tensioner pulley on the rear belt? I'd find that strange having a dealer service history...but then again...
    One of the first things I did when I got my D5 home was replace both timing belts myself...along with the water pump on the front and tensioner pulleys on both even though they'd been marked as replaced at 67k miles on the service history...
    I found out the hard way with my SDV6 D4 that having the belts marked as 'replaced' on the dealer service history meant very little and it cost me a new engine.
    As for your D5... a low pressure fuel pump failure seems fair, but I'd get that rumbling rear tensioner replaced ASP if it isn't already the issue...
  • zig
    Is the low pressure fuel pump not the fuel pump in the tank?
    In which case it is not an engine failure.
    Yup Zig, it's on the top of the fuel tank and a pain to replace...it's not that difficult technically since the pump is only held in the tank by a metal locking ring, there's a couple of electrical connectors and the self sealing couplings on the fuel lines/return to remove... but there's lots of swearing since you have to remove the rear seat base to gain access to the top of the tank via a huge rubber bung under an access panel beneath the carpets and only a few mm clearance when you're pulling the pump out.
    It's not a common fault but it does happen.
    It could also be the crank position sensor, fuel pressure sensor (even a clogged fuel filter or a blown fuse for the LP fuel pump)... or any number of other things fuel related...without plugging a GAP IID tool into it or crawling under and listening for the fuel pump whining away...I'm just guessing Confused
    I'd go with the garage diagnosis to be fair...since they've hopefully run a diagnostic rather than just guessing like I am. The replacement fuel pump isn't that expensive... or difficult to detect if it's actually working or not...but the labour charges involved in replacing it aren't cheap...especially at a dealership since their fitters don't seem to like getting their freshly starched overalls dirty Neutral
  • zig
    Had the low pressure fuel pump fail on a Discovery 3 about 4 years ago with no symptoms in advance.
    The breakdown mechanic, when he eventually arrived, quickly established that it was pump in the tank that was not working (confirmed by not hearing the pump rotating) and once it was checked that the fuse was ok, it was then a matter of having the vehicle recovered to my local Land Rover specialist.
    It is my view that once you get to the point were vehicles have been out there from say 5 years from when a particular model has been introduced, then Land Rover specialist will start to build up a lot more experience as to how to do the repairs, which is experience the Land Rover main dealers don’t build up.
  • zig
    Any update on what this turned out to be.?
