At 120kph I got "Reduced performance" for a few seconds and then "Engine System Failure/ Fault" and it cut out.
Won't restart, simply spins.
I did point out that the something was off when I bought it - like a rumbling wheel bearing - dealer diagnosed a dry auxiliary belt/ bad tensioner (still to be changed) but now it's dead...
Haven't had an official diagnosis yet. Any depressing suggestions, let's hear them
Be optimistic ! at least if the engine spins over it won't be the crankshaft, I would be hoping its the rear belt . Being a TDV6 its probably at the age when both belts should have been changed,
I'm not able to read the codes as it's waiting to be diagnosed - the service history shows that the cambelt service (both belts we would assume) was done 8 months ago, but you never know.
They can a do spin over even with a broken crank but are noisy
