  • Grunders
    2017 Discovery SDV6 HSE Santorini Black
    Pedal Commander
    HI,
    I was looking at the lag from starting on the Disco, I came across the Pedal Commander and the Roar Pedal, it states it eliminates lag and you can change the driving modes
    has anyone fitted one and are they any good?
  • zig
    Which model/engine and model year of Discovery 5 do you have and exactly what do you mean by “lag from starting“?
  • Grunders
    hi,
    its a 2017 TD6, 3.0, its more a hesitation from pulling away from a junction or pulling out at a roundabout, once moving its absolutely fine
  • zig
    Possible problem with EGR valves?
  • Jarvis
    2019 Discovery SDV6 HSE Lux Silicon Silver
    Throttle butterfly sticking?
  • Grunders
    Thanks for the responses… I’ll have a check and feedback
  • zig
    The reason why I suspect the EGR valves is that I had a Discovery 3 with a 2.7 litre TDV6 engine which on a couple of occasions had a fault which meant that when you put your foot down to accelerate at a junction or roundabout there was a long hesitation before the engine started to develop power and move forward. However, once moving the engine behaved normally. Thus you had to wait until there were large gaps in the traffic before attempting to enter the junction or roundabout. On both occasions problem was the EGR valves.
  • Grunders
    i had the car in for service last week (Car Surgery just outside Stoke, highly recommended) they shown me the issue with the butterfly sticking, yesterday in stripped off the throttle body and gave it a good clean (it was heavily carboned up including the MAP sensor, I cleaned the butterfly and sanded the body so the valve was snug but didn't stick at all, put it all together and all seems ok
  • zig
    Thanks Grunders for the feedback.
