I had opened the RH rear passenger door window when I was cleaning the inside of the car today...as I was closing it I heard the dreaded crunching sound of the regulator eating rusty cable. Predictably, the window stuck immovably half way up
I whipped off the door card and plastic access panel, tried to slide the glass up by hand but it was jammed solid. I couldn't even get to the long run of the cable to snip it and free the mechanism up... so, had to pop the glass out of the plastic clips on the regulator frame to allow me to slide it closed. I jammed the glass up with a 15cm long piece of soft wood braced against the centre door frame and refitted the access panel and door card.
The Remote app keeps informing me that the window is open of course so I can't use the climate start until the regulator is replaced and I've recalibrated the windows, but at least the Bling Barge is weather tight without the use of gaffer tape and plastic bags in the meantime.
Bought an 'OE quality' after market regulator from
Ebay for £70 which will hopefully be here by the end of the week...since it's coming direct from Yorkshire instead of China. I seriously hope it's not OE quality, since the expensive Land Rover ones keep breaking.
I won't
ever scrimp on fluids, filters, brake/suspension components or anything structural...but we're talking about a window winder here... you press the button and the window goes up and down. An OE replacement regulator from Land Rover (exactly like the 2 that have already failed on the Bling Barge with the same fault) are £200- £255...each...and good luck finding a Land Rover official stockist that has any on the shelf.
At those Ebay prices and coming from a recognised UK parts supplier, I'm tempted to buy spare regulators for the drivers door and LH rear passenger door... the ones I haven't already had to replace, to stick on the spares shelf in the garage ...just in case. With 2 window regulators having already failed in the year I've owned the Bling Barge...better to have and not need rather than t'other way round, as the saying goes.
Never rains but it pours
