- Chrisholly31
Number plate lights not extinguishing
Good Evening,
First post so please be gentle!
Have recently swapped a D4 for a D5 (2020 SD6 HSE) and have been very pleased so far. It was obviously only a matter of time before the first niggle and I would be very grateful if anyone can advise on the following issue. I’ve searched the forum to no avail.
Essentially, as title suggests the number plate lights are not extinguishing when the car is turned off, locked and alarmed. They do dim, but remain on. I’m clearly concerned about battery drain.
A Google search recommended a hard reset by disconnecting and reconnecting the battery after 15mins. But I just wanted some grown up advice before attempting this.
Any help greatly appreciated.
- Chillyphil
Hi Chris,
Welcome to the forum.
A lot of good guys here who I'm sure will give you good advice.
Phil
- Chrisholly31
Thanks for the welcome Phil. Hope you haven’t been too badly impacted by this weather.
Attempted hard-reset today to no avail. Will go down the warranty route next week and update when issue is known. Dealer has been helpful and thinks it’s either a corroded wire or faulty boot switch.
- Mole HD
Definitely sounds like a bad earth or something. Just as an experiment, if you have the light switch on the stalk set to auto, try turning it to off and check if the number plate lights are still on when you lock the car...
- Chrisholly31
Thanks Mole, tried as you suggested and sadly no joy. Will try local LR specialist tomorrow and get their take. Update to follow!!
- Chrisholly31
Latest update: After a bit of dry weather and a drive this morning number plate lights went off when car was locked (as they should do!) Subsequently put car through the car wash and we are back to the previous issue, dimming to 50% when locked and not going off.
Looking at the lights themselves they have what looks like condensation inside, so am wondering if this is part of the cause.
Have booked in with the local LR specialist on 4 Feb, have also ordered some new lights which I’ll ask them to fit when they do their checks for the root cause of the issue.
Will keep checking over the next few days and see if it stops as things dry out - latest storm may hold up progress!
- Chrisholly31
Fault fixed. Took car to the local LR specialist (Gerald Hallett). Cause of the issue was identified - a corroded connector. Mechanic cleaned this up and fitted new number plate lights (both old ones had water ingress/condensation internally) and both had very corroded connections. Pleased to report all working fine now and thankfully a relatively straightforward fix.
In total 1hr 30mins for garage to find and rectify issue and replacement parts were readily available on E-Bay.
- Mole HD
Top job, Chris. Glad you got it sorted.
