  • andrewspeedwell5
    2021 Discovery Si6 S Kaikoura Stone
    Re: Reversing camera died.
    JonM wrote:
    Common sense would suggest it needs the trim panel removing from the inside of the tailgate, so I'll start there...
    It's really easy.
    1. Remove the torx screw from the handle inside the boot lid.
    2. pull off the panel inside the boot lid. Apart from the screw you've already removed, its just clips that pull off.
    3. Disconnect the interior boot closing switch
    4. Remove the interior LED lights
    5. Put the panel somewhere safe.
    6. Disconnect the camera washer hose
    7. Remove the (6 I think) nuts that hold the external trim strip in place. (don't remove the (3 each side) nuts that hold the lights in place).
    8. Pop the trim strip off.
    9. disconnect the camara cable from the back of the camera
    10. unclip the camera from inside the trim strip.
    11 do all of the above in reverse.
    Followed the above, and apart from NOT disconnecting the washer hose as there was sufficient length on the hose to allow the external trim strip to pull forwards, I have successfully changed the rear view camera on our Disco 5 this weekend. New camera is crystal clear and cost just £60 off eBay !!
    Thanks !!!
    Excellent news... I wish it were just my camera at fault on mine. Thumbs Up
  • Lynchyy
    2020 Discovery SDV6 First Edition Loire Blue
    andrewspeedwell5 wrote:
    It's really easy.
    Thanks !!!
    Hmm, wonder if its worth 'upgrading' camera. The factory camera is awful! Wide lens makes stuff to the left and right of the car seem like your going to hit it. Also the quality is very poor.
  • Beno2
    Do you have photo of the new camera image
  • andrewspeedwell5
    See photo attached. Crystal clear compared to the old one I took out. Part number for my MY 2021 is LR129291 (L8B2-19H422-AD) and cost from £67 on eBay (Land Rover want £360 for the same camera)
  • andrewspeedwell5
  • Beno2
    Looks great Very Happy
  • Lynchyy
    Now to find if that camera fits the 2020 Disco
    They're fairly generic...as in...it's simply a camera. If one works on a 2021 model, it'll work just as well on a 2020 since it has a generic (8 pin I think) electrical connector... If the camera has an LR OE part number, and there's many of them with the same part number fitted to most JLR vehicles and all readily available via eBay etc. I'd be confident in saying, it's good to go. The electrical connector only fits on one way...so it's not like you can fit the camera incorrectly or anything. Thumbs Up
  • Beno2
    Do you have a link to this please
    There may be different versions on different ages of vehicle. When I changed the one on my MY22 D300, the connector was coaxial, not 8 pin.
    This is the correct one for a MY22 D300
    https://ebay.us/m/lxHk5S
    Indeed Jon, many thanks for the clarification and correction...I tend to assume way too much when it comes to newer models... Embarassed
    My reversing camera has weirdly decided to start working again...which kinda suggests it was a PCU based fault (or similar issue) rather than a dodgy earth or damaged wiring causing the insufficient voltage DTC I was picking up with the IID tool. What's strange is that it was only the reversing camera effected, all the rest of them were fine.
    I did initially try replacing the camera unit with the new one I bought from eBay (just to rule it out)...but that came up with exactly the same insufficient voltage error so I refitted the original camera and decided to wait until the Bling Barge has been through the software update at the dealership in a couple of weeks to see if that remedied the fault.
    I've absolutely no idea why it's suddenly decided to unbreak itself, it wasn't working when I reversed out of the workshop this morning...but by the time I had driven the 3 miles to the local shop...it was all of a sudden working as normal when I selected reverse and has been fine since then.
    I really hate intermittent faults of any kind, they're a complete PITA to track and fix. Neutral
    Coming back to this as my reversing camera still has this intermittent working one day, not working the next fault.
    I suspect the intermittent undervolt issue that's plaguing me is down to a tired old battery (which I suspect is OE and now 9 years old) and the BMS (Battery Management System). I disconnected my battery a while back when I was working on the Bling Barge but didn't recode the BMS after reconnecting it.
    The fault doesn't seem like broken wiring or a faulty earth...given the camera works fine but then goes dark with this insufficient voltage error on a completely random basis. The camera had been working fine...then I got the 'Battery low, please start engine' message after not using the car for a few days...and lo and behold, the reversing camera didn't work.
    I've got a new Bosch 95AH battery coming so I'll see if replacing the battery... and the old camera with the new one I bought... plus recoding the BMS will sort this frustrating and annoying reversing camera issue out once and for all.
    Fingers crossed. Neutral
  • StokesyStokesy
    2018 Discovery TDV6 HSE Scotia Grey
    Did the battery make any difference?
