  • Snapper1
    Rear Camera Zoom
    Hi hope somebody can help, i have recently upgraded to a 2025MY Disco from a Disco 4 and my camera doesn't seem to zoom in when hitching up to a trailer, i select reverse camera comes on i select towing and the line changes to a single line from the tow ball, i reverse to the hitch but no zoom when i get close, the manual says it should, the disco 4 you could touch the screen and options came up to turn things like that on and off but i cannot find that, any ideas?
    Series 2A, Series 3, Disco 4 Now Gone Disco 5 Dynamic HSE (Capability plus and Towing Packs)
    It should automatically zoom when 600mm from the hitch in towing mode with MY25 and Pivi pro …yes.
    In earlier models with surround cameras I believe there was a feature to turn the zoom off in the rear camera menu.
    But if you’ve got the single line it’s in the right mode.
    Couple of method queries….
    Does it happen when reversing towards say a wall (not just trailer hitch) in tow mode?
    Have you tried different approach speeds?
    Beyond those….. there were some software issues I read, with this feature that required updates .
    May need software reinstall/update?
    Unlikely …but is the camera alignment slightly off?
    Worth getting a diagnostic on the camera module for errors?
    Is it a deployable or fixed towball? Just wondered if it’s deployable if there is something in the wiring??
    Just a few thoughts
    Someone else may have an answer.
  • Snapper1
    Thanks Wolfpack,
    i haven't tried the reversing towards the wall, will give it a go tonight, might also try low range as well, it is the electrically deployable tow bar, so might try with it deployed and not deployed.
    i haven't tried different speeds, just a steady slow crawl.
    The car is ex Land rover and the tow hitch had never been used so a software issue is probable, so a trip to the dealers is most likely,
    Thanks again, given me some stuff to try first, i didn't want to go and be told you should have pushed this button in this menu over here.
    Yeah …the wall idea is just a bigger field of view in case the camera isn’t “seeing” properly…..please don’t try a faster approach speed on that one Laughing
    I was sat in Tesco carpark this morning while the boss went in for a couple of items. I had the tow ball deployed so I switched to tow mode and reversed back toward the car in the bay behind…..camera zoomed in immediately …so not hitch dependant.
    Sounds like a software update best bet.
  • Snapper1
    Laughing Laughing yes i am not going to speed into the wall, will try it tonight when i get home.
  • Snapper1
    Update, been to the dealers today and no joy, they tried to tell me I might not have hitch assist and got a salesman involved, when he realized I have the towing package and advanced towing pack he said it should have hitch assist. They had another 74 plate D350 there with tow ball so we tried that, which also didn’t zoom in.
    Does anyone else have an issue with this on a 25 MY or does everyone else’s work?
    Can’t believe they would remove something which helps so much, I feel there must be a sub menu somewhere that toggles this on and of but damned if I can find it.
    Mine is the same, no zoom. Deployable towbar, and get the single line to guide the towbar to the trailer but doesn't zoom in as you get closer.
    2019 Discovery HSE SDV6
  • Snapper1
    Thanks Discus, wonder why Wolfmans works and not ours, dealer said they are going to put a query into topix to try to find the problem,
    so far i have found Chester Land Rover very good so fingers crossed
    It can only be the car age and/or software version (stopped updates in 2022)
    2foot from bin
    And in case anyone was curious about the strange “vehicles” to the left of the bin….my water wagons.
    Caravan waste water tanks with permanent long reach drainpipes in lieu of watering cans during the hosepipe ban. Fill 50L from tap and wheel to remote borders, stand it on end for required watering time and move to next dehydrated area…..saves a lot of walking back and forth with 6L watering cans. Laughing
    That looks like InControl screen, wonder if the zoom was only on the Incontrol screen as it was smaller, and Pivi Pro doesn't zoom? Would certainly be better if it zoomed.
    I thought they were some kind of fancy remote control rabbit/mole scarers. Laughing
    One thing we never need up here, watering cans or garden hosepipes...it's been 12° to 17°c and hasn't really stopped raining since the end of March. Neutral
    On topic though...my reversing camera is still only working intermittently...some days it works, some days it doesn't. After a bit of online digging and investigating possible causes for having an insufficient voltage error on the IID tool when I tested the reversing camera feed when not working...it seems like either the camera feed or positive or negative electrical wire has been crimped or deformed through constant bending and straightening up at the top of the boot where it goes through the rubber flexi tube into the car. A problem inherited from certain Jaguar models of roughly the same age as the Bling Barge. Of Course, the Jaguars were all recalled to fix the reversing camera black out issue 8 or 9 years ago. Rolling Eyes
    That's going to be a PITA to trace out and repair as my sparky skills are usually accompanied by lots of blue flashes and shouting. Time for a proper auto sparky to have a look I think. Censored
    Yes …that could be the case.
    I wonder if anyone with pivi pro and deployable towbar can confirm?
    I’ve had AI searching topix and IGUIDE for pivi pro models and it’s failed to find any mention relating to the zoom after 2018 in the tow assist section.
    I gave up on this search when it suggested the next step was for ME to “get in a car of the appropriate spec and have a look myself”
    hmmmmm Ai?
  • Snapper1
    Thanks all for looking, i found the below on the I Guide, i have put my vin number in which doesn't make any difference in the I Guide, Wolfpack for some reason i thought yours was a 2025 Model which got me excited but i have re read your post and realised my mistake, going to carry on pestering LR.
    No mine is an SI6 petrol beastie, pre pivi pro.
    I suspect this difference is more to do with a change in the camera lens that coincided with the change to pivi pro rather than it being the root cause.
    Yet another moment of shortsightedness by JLR….why would a vehicle meant to tow ever have a need for precise hitch assist?
    If it makes you feel any better, the zoom doesn’t make alignment foolproof. I frequently find the arc of the hitch when lowering misses dead centre according to the camera view. There is a need for my own positional adjustment…when I remember which direction I need to go, after weeks of not doing it! Rolling Eyes
