  • winger
    Re: AA Fault report
    stuart_f wrote:
    An email has just arrived from AA describing their attendance at the car today. It contains the fault codes:
    Quote:
    Patrol found the following fault code/s:System : Engine control - 2S8 / Diesel CR/EDC MEDC 17.9 Status :P2610 - ECM/PCM internal engine shutoff. Error Message : Missing message. Historical fault.U008087 - Unknown fault. Error Message : . Status :U0402 - Transmission control unit. Error Message : Malfunction. Historical fault. Status :U0167 - CAN communication with immobiliser. Error Message : Malfunction. Historical fault. Status :P062F - EEPROM error. Error Message : Memory error. Error sporadic.have deleted fault codes.
    Does any of that make sense to anyone?
    Fault code P2610 seems to suggest either a hardware wiring fault or a software communication fault. Difficult to say more really, though some error on the HS CAN might be behind this, which would disappear with a fault clearance and might not materialise again. The historic faults are along the same lines as you can see.
    Re: AA Fault report
    Just an example :-
    Best £50 quid I ever spent. Saved me a fortune
  • stuart_f
    Interesting, thanks RR. I think one of those tools might be a wise investment given the level of reliability so far.
    It's plug and play. Sure its down too £40 now. Thumbs Up
