  • RyanRC
    Disable fuel save engine shuts down at stops?
    Hello all
    I'm not really sure if this is something that happens in Europe or other places this truck is sold, but I have been seeing some American reviews of the truck here now and I guess it has that thing where most times at a complete stop the engine shuts off, then starts again once you take your foot off the brake for the reason I guess is to save fuel.
    So if this is something you guys have too, does anyone know if there is a option in the configurations to disable that?
    I actually had a loaner car about two months ago that did this and found it to be very unsettling.
    Ryan there is a switch next to the Vehicle Height Settings, so you can disable the feature. Thumbs Up
  • J77
    Just remember you have to do it every time you restart the vehicle.
    Gentle pressure on the brake pedal stops it from cutting out.
    Sorry i forgot to mention the Every Time bit Thumbs Up
  • Tim in Scotland
    If you want to use it properly in city driving then you should brake the car to a halt, wait for the engine to stop, engage the EPB, shift into N and the engine will stay stopped and not dazzle the driver behind with the high level brake light. To restart push down the footbrake, engage D then ease off the gas pedal and it will start up again. The system will not work if the engine load is too high like when running seat heaters and heated steering wheel or the engine is not up to temperature or when the external temperature is below 5c IIRC. It is brilliant and now I'm used to it use it all the time, when I first read about my first thought was that it would immediately be disabled. I also find it easier to use on the L494 RRS with a proper "stick" type auto shifter than I did on my 2 Evoques that had the rotary shifter.
  • AndrewS
    After a while you wont notice, I used to turn it off every time but now I just go with it.
    FYI the slightest release in pressure on the brake pedal and the engine will re-start and continue to run until the next time you come to a halt.
  • Scrumps
    If you set the option for the paddles to work in 'D' & 'S', just select a gear when you come to a stop and it won't shutdown, hold the 'up' shift(+) for a few seconds as you move off and it goes back to auto.
    Scrumps.
  • RyanRC
    Wow, thanks guys for all the replies.
    In the end sounds like there is not way at least by the ways from the factory to completely turn it off.
    But thanks for all the other input.
  • RyanRC
    Hello all
    I have been thinking about this for a little bit and it may be a oversimplified question or thought that it could be this simple...but if this is just kind of N/O or N/C switch, has anyone tried to just jump it out?
    Am thinking they may have done something tamper proof to it so would not be possible or that simple, but then again...perhaps its just that easy.
  • neilk
    From memory it is a momentary switch so trying to short it won't work, you would need something that did a delayed closure after startup and then opened again. The stop start makes a big difference to the emissions measurement and compliance (at least to the test regime if not the real world) so I am pretty sure they have to make it reasonably tamper proof.
    It is so seamless I really wouldn't worry about it, the earlier iterations were clunky but I don't even notice it anymore.
  • RyanRC
    Does the switch have the name ATMOS on it?
    If it does I know someone who knows how to disable that.
  • Tim in Scotland
    A button with ATMOS on it sounds more like it is something to do with the ventilation/ recirc system.
  • RyanRC
    Actually it stands for "Atmospheric Omission System" and its products are supposed to be related to lowering your emissions.
    Although its true purpose is another story.
  • Martin
    Site Admin and Owner
    Euro and US cars are likely to have different emissions equipment and software.
    06 D3 SE / 15 D90 XS SW / 88 90 Td5 / 68 BMW 2000 TI
  • DiscoStu
    Thumbs Up Laughing
    Over their heads, I think!
    MY19 Silver HSE Lux SDV6
