      - kid
      cost of fitting a towbarI was speaking to the dealers  about getting a D5 with out a tow bar then may be get one fitted at a later date by the dealers. Electrically Deployable  one. He said that will be OK but will cost you £2200+     .Why so much
      - J77
      Because it's a dealer and all they see is 💷💷💷
 Try Dan@duckworths, he's a forum sponsor so may be able to do you a good price on the parts.
      - Scrumps
      Re: cost of fitting a towbarkid wrote:I was speaking to the dealers  about getting a D5 with out a tow bar then may be get one fitted at a later date by the dealers. Electrically Deployable  one. He said that will be OK but will cost you £2200+ .Why so much .Why so much
 The answer is:-
 Because you can't offset the cost of the tow bar crossmember with the blank one that's already fitted.
 The same applies to the rear tow cover, but you should end up with a pile of leftover bits.
 The price includes fitting, which could have been done as part of the build on the line by the build team, same goes for the software config which would have been part of the original config, PLUS you have pay the Dealers team to take off all the original bits before they can start "fitting".
 Dan@Duckworths will supply the hardware at a reduced price - but you still have to get all the other stuff done.
 Scrumps
      - RyanRC
      - sportcoupe
 Ordered - HSE 3.0 V6 Diesel Kaikoura Stone 20" Black pack + more.
 2016 Jeep Wrangler Unlimited Rubicon
