- Craigp
Powered inner tailgate.
Inner tailgate stopped working electrically. Anyone else had a problem.
- Russell
Mine did once, just pushed it up by hand, close the boot and re-open and it had reset itself
- Craigp
Tried all that just seems dead. May check the fuse. But got to go to the dealers for another problem so will probably leave it for them.
- pdes
Craigp, I now have the inner tailgate problem. Did yours get fixed?
Series 1, 1953, 86"
- Craigp
Yes back to deaĺers. New motor I believe but got a little confused as my main tailgate stopped working from the key fob and his explanation as to the fix through me. Anyway all fixed now.
- Arslanoff
I have a question on the Powered Inner Tailgate work.
- When you open the tailgate from the tailgate button, the Powered Inner Tailgate stays closed.
- When you open the tailgate from the interior, the Powered Inner Tailgate stays closed.
- When you open the tailgate from the keyfob, the Powered Inner Tailgate opens too.
Is it possible to make the Powered Inner Tailgate opening always with the tailgate opening, does not matter how you do it? May me by the dealer software or something like that?
- Chrismcnaz
I would have expected that to be an option.
- Pcheaven
Mine stopped working today
Made a nasty grinding noise, then quit.
Car was due in today for software update for ICP - canceled this appointment this as I needed the car due to snow
- neilk
Mine did the same (March '17 Vintage), the actuator bracket shears, they have a modified stronger bracket (another bulletin on it).
- benlawers
Mine on the second one and failed as soon as the car was delivdered home again this week. I'll re-post once fixed again - booked for 9th November,
- Seaby
A common issue maybe. Mine made grinding noises / stopped working / remote wouldn't open the boot etc.
Booked into the dealers who said they had all the parts already in stock as had a few with this issue. All now fixed for now
- Buttonbar2004
Powered inner tailgate failure
I have a 2017 model and just had the powered inner tailgate fail on me. Booked into dealership next week.
Sounds like a bit of a weak point from all the responses on here.
- TechnoTurkey
The inner tailgate has just failed on my 2017 HSE Lux as well - getting it booked in..
