You are currently viewing DISCO5.CO.UK as a guest - Register  to take part or Log In
      J77
      Windscreen Defrost
      Should the windscreen defrost evenly?
I’m sure the D4 defrosted evenly. I was -1 though so perhaps thicker in places.
      jimbg
      If that is using the heated screen then one half is not working.
I have seen this on a RRS.
Dealer visit called for?
      J77
      That’s what I feared
It was a mix of heated windscreen and blowers.
      simonh
      Next time just use the heated screen. It maybe the blowers are not evenly distributing the heat/Air.
Just a thought.
Served by the excellent Shukers Land Rover of Ludlow - 10 Land Rover’s and  20 years of amazing customer service.
      J77
      I’ll see what it’s like over the next few mornings.
      jimbg
      Of course on the SE the second half of the screen heating was a £1500 option.
      J77
      You know, that wouldn’t surprise me.
      Pcheaven
      If you were using the air blowers at the same time, then for me it would suggest either
The right hand side of the screen had much more moisture.
Or.
The right hand side Air blower is not synchronised properly and had either less Air flow or a different air temperature.
      J77
      I’m going to see what it’s like over the next few mornings. I’ll check both blowers and I’ll also try just the heated windscreen, just need a lot of frost.
      Craigp
      I blame the Christmas tree, Its effecting the air flow. Rosary beads , thats the answer.
      J77
      I’ve even moved the dog from the dash just in case.
      simonh
      The dog does seem to be affecting the ice... its all emanating out of his head !
      J77
      Maybe just his heavy panting
      J77
      Solid frost this morning, heated windscreen on and blowers, everything worked a treat. So all seems well.
      simonh
Was the dog still there though?
  You cannot  create new threads in this forum You cannot  reply to threads in this forum You cannot  edit your posts in this forum You cannot  delete your posts in this forum You cannot  vote in polls in this forum
