  • Rodisco5
    2018 Discovery Td6 HSE Indus Silver
    Keyless. Entry
    Thought this may of interest. The Car tested was a Land Rover Discovery 2018 model.
    CLUB NEWS: SECURITY RISKS FOR KEYLESS ENTRY SYSTEMS REMAIN HIGH, REPORTS ADAC
    18-04-2018
    The Allgemeine Deutsche Automobil-Club (ADAC) has tested 108 keyless entry systems and the LandRover Discovery 2018 is the only car with keyless entry to be protected from hacking.
    Using the ADAC devices, it was neither possible to unlock the LandRover illegally nor to drive off in it. According to the manufacturer, the 2018 Range Rover, Range Rover Sport and Jaguar E-Pace models are also equipped with this technology. However, the retrofitting of other models is not possible.
    It is much easier for thieves to steal a keyless vehicle – where the driver keeps the key fob pocketed – than a vehicle with a conventional remote key fob. Using a self-constructed wireless extender, it took the ADAC engineers only seconds to open the cars equipped with keyless entry systems and drive off in them. The tests left no visible traces of a break-in or theft.
    Because of their obvious security flaws, comfort keys are worryingly easy prey for thieves: it is an easy task to extend the range of the wireless communication between the key fob and the car by up to one kilometre. And this regardless of whether the original key fob is at home or in the car owner’s pocket. Plus, the thieves thus usually also disable immobilisers and alarm systems. The ADAC experts believe that off-the-shelf electronic components are all it takes to easily build your own car theft device. Further models are tested on an ongoing basis.
    ADAC advises its members to take extra care when it comes to storing their key fob. ADAC calls upon carmakers to systematically protect all vehicle electronic systems against theft, as has been standard practice in the IT industry for a long time – ideally in a manner allowing neutral verification, e.g. via Common Criteria. And they should fix/retrofit affected vehicles as soon as possible.
    As it's Land Rover software it probably froze whilst doing the test. They are still trying to get into it even with the key. Laughing
  • samyil
    Smile
  • rogersmj
    I bought these to protect my keys:
    https://www.amazon.co.uk/gp/product/B076V6...&psc=1
    They actually work a treat, once the keys are in these and its closed, it creates a faraday cage and the signal can't get out! They are quite small, so I can only get my D5 key in one (I have 3 other keys on the key fob)
    Bought a total of 4, so I can put spare keys and my wife car keys in them.
    Do we know if the 2018 model uses different keyless tech to the 2017 model ?
  • rogersmj
    The keys definitely look very different. The 2017 model is rounded, a bit like a Disco Sport one. However the 2018 one is slightly bigger and squarer than the 2017 one. Same 4 buttons
    Sure - but is it a different system or just a new key design ?
  • rogersmj
    Yeah, a good question! No idea... Confused
  • Chalkys HSE
    Even if the 2018MY has a different system, it wont take long before that systemn is breached, that's the way vehicle security has been since the late 80's, every time a new alarm or immobiser is revealed there's a cheat to circumvent the security.
    The key's themselves emit a constant RF signature, i was told recently that this can be grabbed and replicated with not much more than basic componenets some wire and a Pringle crisp tube acting as a dish.
    Quite frankly, that's pathetic Shocked
    I awoke last week to a knock on my door, my neighbour had his BMW stripped of it's Front & Rear bumpers, seats, dash, steering wheel, the lot !
    Taped up his lights so they wouldnt flash and activate, then set about stripping it. same method used to grab the code from his keys from within the house and amplify the signal to pop the doors.
    I do have a Black Matter ipad case that i keep my key's in "If i remember" Rolling Eyes
    But an Old holborn tin or an altoids tin works just as well. Thumbs Up
    DO NOT do what my mate did, came home from work late, chucked his keys in the oven, Because that's like a Faraday cage apparently....... Hey presto....... wife turns oven on, shortly afterwards "ere, What's that smell" ?
    Rolling with laughter
  • rogersmj
    LOL Rolling with laughter
    Bet thats bought up everytime theres an argument!
  • DG
    Seems that the new tech on the D5 can work out the distance the signal has had to travel from the key even if it's been boosted by a thief gadget ....if it's over a prescribed distance then the system shuts off. This means I guess that you truly have to be stood next to the motor for the key to operate.
    Assume the buttons still work at distance ?
  • Rodisco5
    If you can read German go to the zADAC web site, there is a great deal more info on the testing they have done and how. For once it may be unbreakable no promises. ADAC are renowned for their testing and results. Everything known has failed to break in. It is a new Sytstem on 2018 models completely new, older versions cannot be updated.
    Please dont shoot the messenger, I am only trying to provide some very up to date information. Let’s hope it proves to be correct for a reasonable time, it needs to be!!
    Rodney
    I’m pretty sure if LR wanted to fit it to older vehicles it could be done. It’s a transmitter and receiver and new key. Unless it’s all buried deep in the D5 and inaccessible there’s no reason why it couldn’t be done.
  • DiscoStu
    I can confirm that it works on a MY18.
    My car is still on my drive...
    MY19 Silver HSE Lux SDV6
