- bammmy
SD6 2019 Oil dilution.
SD6 Oil dilution.
I am not far off about to order a new 2019 D5, what I am slightly concerned about is the oil dilution issues. How are things going with this newer engine, I have read lots of articles about the single turbo engine and am hoping that the newer engine has few oil issues.
The engine I’m after is the 3.0L 306 bhp version.
I have just heard today it is cured, any thoughts appreciated.
Thanks in advance....
- Labbix
With the outstanding campaign N222 it should be fixed for the MY18 TD6 as well, and hopefully it works, and they will do the same for the MY17. No idea about the MY19 as it is still a bit early, but if JLR hasn’t fixed it after 3 years of well known issues, I doubt they will fix it at all.
- 747_JK
I’m 1,250 miles into ownership and first service interval still reporting correctly... fingers crossed!
- Pcheaven
- Qwertyd5x
What is the campaign N222?
- Labbix
From an earlier post:
service bulletin N222 (issued 5/10/18 ) for TDV6 engines that requires a Powertrain Control Module update and an oil and filter change if the vehicle is below 75% of its next service interval.
Publication No.: N222
Model: Discovery (LR)
Model Year: 2018
VIN Range: 030810 - 079568
Model: Range Rover (LG)
Model Year: 2018
VIN Range: 360475 - 516163
Model: Range Rover Sport (LW)
Model Year: 2018
VIN Range: 693135 - 813912
Model Year: 2018
VIN Range: 163397 - 414420
Date of Issue: 05/10/2018
Expiry Date: 31/10/2020
- Labbix
From Bigwhiteone:
‘There is a major software and systems upgrade (released October 2018) that ‘allegedly ‘ fixes the problem by changing the way the software measures the oil contamination and assess its continued viscosity: that’s the sum total of my technical capability completely exhausted. When upgrading the software your dealer should also change the filter and oil to recalibrate everything’
- Mightymildred
Mine had this last week.
I doubt it will change anything..... but I will know in 5-6 weeks time.
- GP1200
I hope so too, I’m going back to the dealer now every 7 - 8 weeks.
This time it didn’t even give countdown, Just service required.
I’m getting just 7000 km between services with mostly freeway traveling.
2018 D5 HSE LUX TD6
- Flat Earther
Do bear in mind that the engine has no way of assessing the level of oil contamination, the software purely counts the number of times that the engine is switched off mid generation cycle. So, unless there have been significant hardware improvements, or a new way of regenerating the DPF, I’d be concerned that they’d simply changed the acceptable amount of engine stops between services and to hell with the contamination.
I hope I’m wrong and they’ve hit on a magical cure
- DieselRanger
Based on my oil analysis on the Td6 engine, the software over-estimates dilution by 3% up to 6.1% (i.e., zero detectable FIO, but the vehicle thinks it's time for a change). So maybe this isn't a bad thing.
- Flat Earther
Now, that’s the sort of information that we need
- Qwertyd5x
My car has just had the N222 update, but dealer told me the car is not fixed and to expect repeat early services. Mine managed only 4,700 miles.
- GP1200
Mine managed only 5500 km ( I thought it was 7000 km ) between services
I oil sampled again, so will wait for the results.
Jack
2018 D5 HSE LUX TD6
- bammmy
Hi Qwertydx5,
Which engine and year do you have please.
Mark
