- IndusD4
Manual Tight Tolerance Mode
On the D5 you can set the car into tight tolerance mode manually should anyone need this.
The procedure is as follows:
Gearbox in Park
Start the engine
Set the suspension to Normal height
Open the drivers door
Press the brake pedal lightly 3 times letting the pedal come up fully each time
And close the door within 10 seconds from first press of the brake pedal.
There will be 2 chimes from the instrument cluster after the door is closed, if successful. Each time the door is opened and closed 2 chimes will sound indicating it is still in tight tolerance mode.
To deactivate:
Either turn the engine off, or drive it over 5mp/h (8km/h)
If you were to use this procedure for wheel alignment you need to have the engine running the whole time.
- Russell
๐
How did you find that
- IndusD4
I could boast about trail and error. But no, from the workshop manual.
- gavinadams
With this mode on, what does it actually change on the vehicle?
- IndusD4
Hi Gavin,
Normally the air suspension doesn't self level until it has to adjust by a certain number of mm (I thought 10 but happily be corrected). This doesn't suit doing wheel alignments so in tight tolerance mode it adjusts quicker (not sure but may be 2 or 3 mm when it adjusts).
Regards
- IndusD4
Seems I wasn't far off. This is from the IIDTool manual:
This will set the EAS ECU into tight or normal tolerance mode. In normal tolerance mode, the EAS ECU
will adjust a corner when itโs +/- 10 mm or higher than the desired height. For example if the corner is
at +9 mm, it will not correct the height. If the corner is at +11 mm, the EAS ECU will make adjustments.
In tight tolerance mode, a tolerance of +/- 3 mm is used.
- gavinadams
Thanks a good thing to know about especially if I get a wheel alignment done somewhere other than jlr service
- Alski
