    Manual Tight Tolerance Mode
    On the D5 you can set the car into tight tolerance mode manually should anyone need this.
    The procedure is as follows:
    Gearbox in Park
    Start the engine
    Set the suspension to Normal height
    Open the drivers door
    Press the brake pedal lightly 3 times letting the pedal come up fully each time
    And close the door within 10 seconds from first press of the brake pedal.
    There will be 2 chimes from the instrument cluster after the door is closed, if successful. Each time the door is opened and closed 2 chimes will sound indicating it is still in tight tolerance mode.
    To deactivate:
    Either turn the engine off, or drive it over 5mp/h (8km/h)
    If you were to use this procedure for wheel alignment you need to have the engine running the whole time.
    ๐Ÿ‘
    How did you find that
    I could boast about trail and error. But no, from the workshop manual.
  • gavinadams
    With this mode on, what does it actually change on the vehicle?
    Hi Gavin,
    Normally the air suspension doesn't self level until it has to adjust by a certain number of mm (I thought 10 but happily be corrected). This doesn't suit doing wheel alignments so in tight tolerance mode it adjusts quicker (not sure but may be 2 or 3 mm when it adjusts).
    Regards
    Seems I wasn't far off. This is from the IIDTool manual:
    This will set the EAS ECU into tight or normal tolerance mode. In normal tolerance mode, the EAS ECU
    will adjust a corner when itโ€™s +/- 10 mm or higher than the desired height. For example if the corner is
    at +9 mm, it will not correct the height. If the corner is at +11 mm, the EAS ECU will make adjustments.
    In tight tolerance mode, a tolerance of +/- 3 mm is used.
  • gavinadams
    Thanks a good thing to know about especially if I get a wheel alignment done somewhere other than jlr service
  • Alski
    Northern Ireland
    Great Tip - Thanks
